Walkera +deviation firmware+which simulator?
- EduardS
20 Oct 2013 12:34 #14801
by EduardS
Replied by EduardS on topic Walkera +deviation firmware+which simulator?
Is it possible that Deviation 8S latest nightly build doesn't give any PPM output? With Deviation 10 3.0 I don't have any problem with my simulator.
20 Oct 2013 15:08 #14809
Replied by rbe2012 on topic Walkera +deviation firmware+which simulator?
No,
I just tested with my Devo8s and encountered no problem. There is no general issue (i use ClearView).
- EduardS
20 Oct 2013 19:34 - 20 Oct 2013 19:35 #14816
by EduardS
That is weird. With Devo 10 with Deviation 3.0 I have no problem with my simulator (Phoenix), but with Devo 8S on latest nightly build, Pnoenix recognizes the transmitter but there is no channel activity on all channels.
Last edit: 20 Oct 2013 19:35 by EduardS.
20 Oct 2013 20:31 #14817
Replied by FDR on topic Walkera +deviation firmware+which simulator?
Did you compile that?
The development compilation uses the trainer port for debug messages, so there is no PPM out if you compile that way...
21 Oct 2013 06:27 #14823
If you have compiled with the option "dev" (make TARGET=devo8 dev) the trainer port is used as as serial out.
- EduardS
21 Oct 2013 08:27 #14826
by EduardS
It's not compiled, it's the downloaded version. Gonna try the 3.0 version for the 8S this evening (CET).
21 Oct 2013 10:35 #14827
I tested it with the actual nightly again - also no problems.
- EduardS
21 Oct 2013 16:26 - 21 Oct 2013 16:27 #14840
by EduardS
Sorry my mistake.
It's working now. I turned on the transmitter connected to the pc and then selected the simulator model. When I turn on the transmitter after connected to the pc with a simulator model already selected all channels are giving output. Thanks for all feedback to my question and sorry I took your time unnecessary.
Last edit: 21 Oct 2013 16:27 by EduardS.
21 Oct 2013 16:37 #14842
Replied by vlad_vy on topic Walkera +deviation firmware+which simulator?
You can press 'Re-Init' button after you select simulator model (PPM).
- EduardS
21 Oct 2013 17:25 #14848
by EduardS
Thanks for the tip vlad. That works also.
- Josegonzalez1985
08 Oct 2016 06:57 #54707
by Josegonzalez1985
Replied by Josegonzalez1985 on topic Walkera +deviation firmware+which simulator?
Thanks for the info fellas, I was able to connect my devo 10 deviation to my pc easy, juSt had to select ppm as the protocol and connected right up
Time to create page: 0.909 seconds
- Walkera +deviation firmware+which simulator?
