Help Hubsan X4
06 Mar 2013 00:05 #7400 by blackmoon
Replied by blackmoon on topic Help Hubsan X4
Did you try putting the throttle trim to the bottom?
Had the same behavior with my wk 4#3, it would bind but no throttle.
Put the trim at bottom and the little bird woke up.
06 Mar 2013 03:42 - 06 Mar 2013 03:43 #7404 by vlad_vy
Replied by vlad_vy on topic Help Hubsan X4
It's frustrate me, seems it related to protocol changes. Just yesterday I got my Hubsan X4 and now I'm in some doubt about Flysky mod.
Last edit: 06 Mar 2013 03:43 by vlad_vy.
06 Mar 2013 06:14 #7414 by PhracturedBlue
Replied by PhracturedBlue on topic Help Hubsan X4
Vlad,
Does it bind? I believe others have reported that the Hubsan X4 will bind but will not fly for versions with the 'different' protocol. Given what MolaMola reported, it sounds more like there is something I'm missing in the protocol, rather than a change in it.
06 Mar 2013 06:24 - 06 Mar 2013 08:06 #7415 by vlad_vy
Cann't say, I didn't implement Flysky mod up to now. Two modules A7105-500m waiting my free time.
Last edit: 06 Mar 2013 08:06 by vlad_vy.
06 Mar 2013 08:45 - 06 Mar 2013 08:47 #7420 by blackmoon
I asked on a X4 topic on RCG.
The V2 and V3 revisions of the board fly just fine with a V1 transmitter.
Maybe they just blacklisted the TX ID you use in deviation ?
Or just something with the model file ?
I'm lucky, the two X4 that I have, fly just fine with deviation.
Last edit: 06 Mar 2013 08:47 by blackmoon.
08 Mar 2013 13:08 - 08 Mar 2013 13:09 #7528 by vlad_vy
I'm lucky, my Hubsan X4 bind and fly, with both my Tx (with A7105-500m module). It has EA4000362 board.
Last edit: 08 Mar 2013 13:09 by vlad_vy.
10 Mar 2013 03:32 #7578 by PhracturedBlue
I believe I have fixed the issue with the Hubsan protocol. the fix is in the latest nightly.
It turns out that I was missing a single command right after the end of binding. For some reason it impacts some Hubsan X4s and not others.
I would like confirmation from anyone who has a non-working Hubsan that it now works properly when using the current nightly build (5b5a0db83c25 or newer)
10 Mar 2013 05:43 #7584 by MolaMolaFalcon
Replied by MolaMolaFalcon on topic Help Hubsan X4
Hell yeah!
It flies my X4 with EA4000363V3 board perfectly!
10 Mar 2013 07:35 - 10 Mar 2013 07:40 #7587 by nanamo
Replied by nanamo on topic Help Hubsan X4
This is wonderful!
All my problems were solved.
It checked by the substrate of my stock.
EA4000362 and EA4000363V3 Both operated normally.
It is very gratitude!
Last edit: 10 Mar 2013 07:40 by nanamo.
10 Mar 2013 08:41 #7589 by stevecox
Replied by stevecox on topic Help Hubsan X4
+1 here, works perfectly. I just want to express my gratitude for the whole Deviation project and all involved. I feel guilty sometimes that I am not able to contribute much for what I get in return and seem to just leach off everyones effort, myself enjoying the software. I will sure help in the odd spot here and there where I can though.
Kudos to all!
Adelaide
10 Mar 2013 11:32 #7591 by vlad_vy
What is the maximum useful travel for channels? 100%? 125%?
10 Mar 2013 12:45 #7596 by blackmoon
If I remember well from my tries, 100% it flips (I fly over concrete, not to friendly for the plastic parts :p), I have set my scale to 90%, it's very nice.
10 Mar 2013 13:53 #7604 by PhracturedBlue
Many thanks to MolaMolaFalcon for providing me a board I could test with. This wouldn't have happened otherwise.
10 Mar 2013 14:13 - 10 Mar 2013 14:36 #7607 by vlad_vy
blackmoon wrote: If I remember well from my tries, 100% it flips (I fly over concrete, not to friendly for the plastic parts :p), I have set my scale to 90%, it's very nice.
I'm asked about phisical limits of the protocol or Hubsan itself. For my taste Hubsan X4 is too inert, I'm using up to -30% expo value for 80% scale and -20% expo value for 100% scale.
Last edit: 10 Mar 2013 14:36 by vlad_vy.
10 Mar 2013 15:45 #7612 by Resonance
Replied by Resonance on topic Help Hubsan X4
Thanks PB and MolaMolaFalcon, my X4 flies perfectly.
11 Mar 2013 02:57 #7628 by cmpang
Replied by cmpang on topic Help Hubsan X4
Resonance wrote: Thanks PB and MolaMolaFalcon, my X4 flies perfectly.
+ 1
11 Mar 2013 06:44 #7634 by netdot123
Replied by netdot123 on topic Help Hubsan X4
Thanks PB & Comrades,my X4 fly ok!
11 Mar 2013 12:53 #7643 by MolaMolaFalcon
Again, Thank you PB! You've solved the issue so fast!
Also, everyone's reports and discussions were exact and interesting.
Now, with my micro quads, I see again that the Deviation firmware is fantastic!
15 Mar 2013 12:22 #7784 by seb
Replied by seb on topic Help Hubsan X4
hi
i installed last Nightly Builds but problem now i only see ,;:!!?./§% ect ect
who can send me good file
thanks
  • rbe2012
  • rbe2012's Avatar
15 Mar 2013 13:00 #7785 by rbe2012
Replied by rbe2012 on topic Help Hubsan X4
Is this your first deviation install? Did you format the USB file system and copied the necessary files and directories in there?
If not, please read the manual first...
Time to create page: 0.891 seconds
