Help Hubsan X4
15 Mar 2013 13:06 - 15 Mar 2013 13:10 #7786 by seb
Replied by seb on topic Help Hubsan X4
Is this your first deviation install? NO
Did you format the USB file system and copied the necessary files and directories in there? YES
Problem come when i install nightly build (5b5a0db83c25 or newer)
i just want resolv problem with X4 bind
Last edit: 15 Mar 2013 13:10 by seb.
15 Mar 2013 13:27 #7788 by stevecox
Replied by stevecox on topic Help Hubsan X4
Similar thing happened to me, use the new filesystem and only copy the models across. I use to just copy the whole filesystem across back n forth but this happened to me and just copying models & icons it then worked right.
Adelaide
15 Mar 2013 16:43 #7791 by seb
thanks stevecox work fine.
and thanks for all for deviationtx
16 Mar 2013 00:58 #7794 by cmpang
Replied by cmpang on topic Help Hubsan X4
any idea what is the difference in X4's expert and normal flight mode other than greater stick rate?
Time to create page: 0.184 seconds
