Help Hubsan X4
- seb
15 Mar 2013 13:06 - 15 Mar 2013 13:10 #7786
by seb
Replied by seb on topic Help Hubsan X4
Is this your first deviation install? NO
Did you format the USB file system and copied the necessary files and directories in there? YES
Problem come when i install nightly build (5b5a0db83c25 or newer)
i just want resolv problem with X4 bind
Last edit: 15 Mar 2013 13:10 by seb.
- stevecox
- Keep swinging
15 Mar 2013 13:27 #7788
by stevecox
Adelaide
Replied by stevecox on topic Help Hubsan X4
Similar thing happened to me, use the new filesystem and only copy the models across. I use to just copy the whole filesystem across back n forth but this happened to me and just copying models & icons it then worked right.
Adelaide
- seb
15 Mar 2013 16:43 #7791
by seb
thanks stevecox work fine.
and thanks for all for deviationtx
- cmpang
16 Mar 2013 00:58 #7794
by cmpang
Replied by cmpang on topic Help Hubsan X4
any idea what is the difference in X4's expert and normal flight mode other than greater stick rate?
Time to create page: 0.401 seconds
- Help Hubsan X4
