Walkera Devo F7 Transmitter Menus
- Terry
21 Jul 2013 08:44 #12394
by Terry
Replied by Terry on topic Walkera Devo F7 Transmitter Menus
Hey. I am new to this field. I have a QR X400 + F7 Devo radio. Can you help me. I need a good F7 radio to Regulation Radio settings QR X400 chopper.
Walker PDF manual does not benefit me Because It can not be a language to translate with Google.
I do not speak English, my language is Finnish and Spanish.
My helicopter engines do not RESPOND to the F7 with the radio. Only the video camera respond.
All other instruction can be found on the Internet, but the exact F7 radio set QR X400 has not been on the internet.
I am happy if you have the time to help me
best regards
Terry
best regards
Terry
21 Jul 2013 09:22 #12396
Replied by vlad_vy on topic Walkera Devo F7 Transmitter Menus
You can download QR X400 setup for Devo F7
www.walkera.com/en/progoods.php?id=495&type=control
www.walkera.com/en/upload/parameter/QR%20X400-FPV-F7.bin
Then, you neen to use Dfuse tool and upgrade model setup at Dfuse 'Config' tab. Select downloaded .bin file at 'Upgrade or Verify File' section, select 'Number' for your model, then press 'Upgrade' button.
www.walkera.com/en/updater.php
Last, you need select model and bind QR X400 to Devo F7.
- Terry
21 Jul 2013 14:04 #12401
by Terry
Thanks for the reply.
I do not open the file because the file is a bin. What program do you use?
Terry
Terry
- nevilos
24 Jul 2013 14:17 #12469
by nevilos
Replied by nevilos on topic Walkera Devo F7 Transmitter Menus
Does this mean Deviation would work with a Walkera Devo F7 and still be able to stream FPV video to it? ^_^
- RandMental
24 Jul 2013 14:46 #12470
by RandMental
Replied by RandMental on topic Walkera Devo F7 Transmitter Menus
Hi Guys
Devation does not support and connot run on the Devo F7 TX hardware, Vlad only assisted with advice because he knows the Walkera environment.
Time to create page: 0.295 seconds
- Walkera Devo F7 Transmitter Menus
