WK 2801Pro and Devo10 Deviation buddy box?
22 Feb 2013 13:27 #6805 by SQRTneg2
I have a WK2801Pro that I love, has served me faithfully for years, but Walkera has left me high and dry with it. If I get a Devo 10 and put Deviation on it will I be able to use the WK2801Pro to buddy box and such?
I suspect I can, but I figured I should ask.
BTW, I'm SQRT(-2) on Helifreak. Just no punctuation allowed here.
Abandoned WK2801Pro user
  • rbe2012
  • rbe2012's Avatar
22 Feb 2013 13:32 #6807 by rbe2012
Replied by rbe2012 on topic WK 2801Pro and Devo10 Deviation buddy box?
For now we have only PPM out from deViation so you only could use the Devo10 as the slave and the WK2801 as master (I hope I didn't mix it up again...). PPM in is on the list.
22 Feb 2013 16:18 #6823 by domcars0
Replied by domcars0 on topic WK 2801Pro and Devo10 Deviation buddy box?
RBE is right (I've tested it as I've also a Devo10 & a WK2801) ...
Devo10 as slave and WK as master works like a charm...
22 Feb 2013 19:52 #6839 by SQRTneg2
Replied by SQRTneg2 on topic WK 2801Pro and Devo10 Deviation buddy box?
Good to hear. If it allows me to do the trainer thing it may be worthwhile to upgrade.
BTW, I am unsure how radio S&M works so which is the slave and which is the master?
  • rbe2012
  • rbe2012's Avatar
22 Feb 2013 19:55 #6840 by rbe2012
The slave if the one whos output is mixed to the masters inputs and then send to the model. So the master has the power to overwrite everything the slave sends him and to decide which value the rx will get.
22 Feb 2013 20:18 #6842 by SQRTneg2
Ah, so I set my 2801 up with the model, and the teacher uses that while the devo 10 is what the student uses as a set of remote sticks.
Thanks guys.
Man, I am not looking forward to resetting up my models with a new radio. But I figure I can do it one model at a time.
Time to create page: 0.106 seconds
