Devo 12s reverse trim switches
10 Mar 2013 12:19 #7592 by gmcquet
Devo 12s reverse trim switches was created by gmcquet
Hi all.
I have noticed that my aileron trim on my devo 12s is somehow reversed.
Example: When I give right stick, I get right aileron up (and left down obviously.
When I give right trim I get right aileron DOWN and left aileron UP which is confusing when trying to trim the model in the air. My Devo 10 does not do this.
I tried reversing the aileron channel and of course the trim changes to the correct direction but the aileron is then reversed which gives me a new problem.
Is there a way to independently change the direction of the trim switches?
All help appreciated!! :)
10 Mar 2013 12:32 - 10 Mar 2013 13:23 #7594 by Hexperience
Replied by Hexperience on topic Devo 12s reverse trim switches
--- doh --- :whistle:
Last edit: 10 Mar 2013 13:23 by Hexperience.
10 Mar 2013 13:16 #7598 by gmcquet
Replied by gmcquet on topic Devo 12s reverse trim switches
Hi. Sorry I forgot to mention this.
My Devo 12s is just stock it's not on deviation. I have my Devo 10 on deviation.
Does the stock firmware allow you to configured trim switch directions?
10 Mar 2013 13:24 #7599 by Hexperience
I've never used the stock firmware....
10 Mar 2013 13:26 #7600 by gmcquet
Hi mate. Well on deviation, can you reverse trim directions without reversing the direction of the stick that the trim is associated to?
10 Mar 2013 13:29 - 10 Mar 2013 16:57 #7601 by Hexperience
---edit---
FDR corrected me below...
Last edit: 10 Mar 2013 16:57 by Hexperience.
10 Mar 2013 14:48 #7609 by FDR
Replied by FDR on topic Devo 12s reverse trim switches
Hexperience wrote: No, trim works in the direction of the channel. + is + and - is -.
Well, you can reverse the trim buttons...
10 Mar 2013 15:35 - 10 Mar 2013 15:36 #7610 by Hexperience
Oh you're right of course! I got caught not pressing the button again...
Last edit: 10 Mar 2013 15:36 by Hexperience.
10 Mar 2013 15:57 #7613 by gmcquet
Is this only in Deviation? Can you reverse trims with stock firmware?
10 Mar 2013 20:24 #7623 by gmcquet
HI all.
I have figured out the issue. There is an option on the devo called STICK DIRECTION. This was set to reverse for the ailerons. I tested the setting out and it allows you to reverse elevator/rudder/throttle/aileron without reversing the trim associated it. Now that it's set to normal, my aileron trim issue is gone. If you havethe stick direction reversed for ailerons they won't match up to the aileron trim direction.
Just FYI..
Time to create page: 1.203 seconds
