module antenna component
- kenkenlau
23 Apr 2013 08:28 - 23 Apr 2013 09:58 #9150
by kenkenlau
module antenna component was created by kenkenlau
Last edit: 23 Apr 2013 09:58 by kenkenlau.
- RandMental
23 Apr 2013 19:02 - 23 Apr 2013 19:12 #9162
by RandMental
Replied by RandMental on topic module antenna component
My guess would be, based on location right before the antenna, it is either a balun to do impedance matching between the board and antenna, or a rf switch.
A balun will have (almost) zero resistance between the in and out pins.
If you could trace the connections to it, it might allow a better guess.
(Google for "2.4GHz balun" to see if it is similar)
Last edit: 23 Apr 2013 19:12 by RandMental.
- kenkenlau
23 Apr 2013 23:28 #9166
by kenkenlau
Replied by kenkenlau on topic module antenna component
Yes, I think so. I did not see this in the reference design inside the datasheet of T212.
Should the impedance be 50ohm with resistance 0hm? or other value to match specific antenna?
- mono
24 Apr 2013 02:54 - 24 Apr 2013 02:57 #9168
by mono
Replied by mono on topic module antenna component
To my knowledge, Walkera have been using that same component in all their 2.4GHz radios.
Datasheet for that component is here....
info.tactnet.co.jp/soshin/j/product/pdf/MDR747F.pdf
Last edit: 24 Apr 2013 02:57 by mono.
24 Apr 2013 04:06 #9169
Replied by vlad_vy on topic module antenna component
I think all RF devices/cables use impedance 50ohm. Only TV devices/cables use impedance 75ohm.
- RandMental
24 Apr 2013 09:41 - 24 Apr 2013 09:43 #9172
by RandMental
The through-resistance of a balun measured with a multimeter using DC current is practically Zero ohm. At 2.4GHz it does both balance-to-unbalance and impedance conversion, typical 200ohm balanced (board side) to 50ohm unbalanced (antenna side) normally onto a 50ohm coaxial cable like RG174. (In such a case it would be a 4:1 Balun).
EDIT: To me it looked like a rectangular 6 pin device, after a second look it is more likely the filter as stated above.
kenkenlau wrote: Should the impedance be 50ohm with resistance 0hm? or other value to match specific antenna?
Last edit: 24 Apr 2013 09:43 by RandMental.
Time to create page: 1.384 seconds
- module antenna component
