need some help with a config
- birwin353
03 Jul 2013 17:09 #11811
by birwin353
need some help with a config was created by birwin353
I set up these setting to use aux4 on my devo 10 as my throttle to do some messing around. It works on the emulator fine but on the Tx it dosent. in channel output when i switch to FMOD1 throttle goes to 0 and have no control with the aux knob. anyone know what I am doing wrong??
- myxiplx
03 Jul 2013 20:31 #11820
by myxiplx
Replied by myxiplx on topic need some help with a config
I had the exact same problem, it sounds like calibration, until you calibrate the aux4/5 controls they stay at a fixed value.
Go back to the transmitter calibration and make sure to turn both of these to their full extents as well as moving your sticks.
- birwin353
04 Jul 2013 04:04 #11841
by birwin353
Replied by birwin353 on topic need some help with a config
that was it thank you so much. I calibrated it but forgot the knobs doh! I am still learning i appreciate it.
Time to create page: 0.037 seconds
- need some help with a config
