Creating a complex throttle mix, with two safeties
08 Jul 2013 17:53 #12101
Replied by FDR on topic Creating a complex throttle mix, with two safeties
Please, post the current config, I'll take a look...
- myxiplx
08 Jul 2013 18:35 #12103
by myxiplx
Replied by myxiplx on topic Creating a complex throttle mix, with two safeties
Here you go, I'm running v3.0.0 on a Devo 10.
08 Jul 2013 19:52 #12105
I think the THR is fine now. I had to disable the trims on the idle page too...
I'm a bit unsure about the trim range, because it has changed recently.
I sware it was +-100 steps, but now it looks to have +-200 steps on the recent emulator...
Anyway you can adjust the idle range in the mixer with the scale and offset...
- myxiplx
08 Jul 2013 20:26 #12106
by myxiplx
Thanks!! I took out the scales and offsets, they're not actually needed. I've got the full throttle range on all flight modes, and the idle / TH value can be configured for anywhere from -100 to +100 in steps of 1.
Works an absolute treat!!
08 Jul 2013 20:31 #12108
OK, fine. I just thought the idle should be in some limited range...
FYI: I see you've set the fail-safe values, but you should know, that he WK2801 doesn't support them...
Time to create page: 0.111 seconds
- Creating a complex throttle mix, with two safeties
