Devo 10 Bench Reboot
10 Aug 2013 15:29 #12887 by notyet
Devo 10 Bench Reboot was created by notyet
I was sitting at the table working on my master CP which has stripped servos (of all things) with my Devo 10 powered up. I heard it beep and buzz and looked over to see the deviation logo on and backlight on.
It had been probably 20 minutes since I'd touched it.
Here's the error file:
[Soft fault]
devo10-v3.0.0-f595de
R0 = 40003800
R1 = 00000000
R2 = 00000001
R3 = 00000082
R12 = 00000036
LR [R14] (subroutine call return address) = 080097b1
PC [R15] (program counter) = 080221d8
PSR = 6100002e
BFAR = e000ed38
CFSR = 00000000
HFSR = 00000000
DFSR = 00000000
AFSR = 00000000
SCB_SHCSR = 00000000
Top of Stack:2000c000
Stack Detect:2000bf88
Backtrace:
2000bf9c : 080097b1
2000bfb4 : 08019f37
2000bfb8 : 08019ef9
2000bfcc : 080059ef
2000bfec : 08005637
Done
Does this indicate anything useful?
10 Aug 2013 18:35 #12891 by PhracturedBlue
Replied by PhracturedBlue on topic Devo 10 Bench Reboot
I don't keep the nightly build .elf files, so your backtrace is not useful unless you also have the corresponding .elf file. That is why I include it in the zip...so you can send it back when you have an issue.
If you have it though, and post it here (or bitbucket), I can hopefully debug though. To post it here, make sure to zip it 1st.
10 Aug 2013 19:33 #12892 by notyet
Replied by notyet on topic Devo 10 Bench Reboot
I remember you saying that so I kept it. :)
10 Aug 2013 21:29 #12895 by PhracturedBlue
This issue should have been fixed in version 9a3467b34f51 which was released on June 15th. I recommend upgrading to a more recent nightly.
(Your logs are from version f595dee33c2f which was released on June 11th)
10 Aug 2013 23:31 #12898 by notyet
Thanks for checking it out for me. I'll upgrade shortly.
...and thanks to you and everyone else that is involved in deviation. I really, really appreciate your time and hard work.
Time to create page: 0.617 seconds
