DEVO 10 WON'T ARM HEX-COPTER
- JH
17 Sep 2013 18:24 #13864
by JH
DEVO 10 WON'T ARM HEX-COPTER was created by JH
I’m having a mysterious problem with my Devo 10 transmitter:
I noticed that I had lost the settings for my hex-copter when the controls were reversed. The Devo 10 had lost the reverse settings and the throttle curve I had put in.
So I reset those and now the copter will not arm. I’m using a KK2 control board so I can see on its screen that the TX, RX, and the KK2 are communicating well – all my stick movements show up on the KK2 screen. But when I try to arm it, nothing happens. It just remains in safe mode.
I’m hoping someone here may be able to suggest something else I can check or do. At this point I cannot even diagnose the problem.
Thanks for any clues.
- stevecox
- Keep swinging
18 Sep 2013 04:17 #13872
by stevecox
Adelaide
Replied by stevecox on topic DEVO 10 WON'T ARM HEX-COPTER
On a DSM2 rx you may need to increase values to 125% to get to the values needed ...
Adelaide
18 Sep 2013 04:18 #13873
Replied by FDR on topic DEVO 10 WON'T ARM HEX-COPTER
...or you can try to calibrate the ESCs...
Time to create page: 0.071 seconds
- DEVO 10 WON'T ARM HEX-COPTER
