Help needed with delta plane model configuration.
- EduardS
07 Oct 2013 15:54 - 07 Oct 2013 16:07 #14308
by EduardS
Help needed with delta plane model configuration. was created by EduardS
hi all, I'm new to deviation and trying to add some models to my Devo 8s transmitter. 3 and 4 channel 'normal' planes I have no problem with but now I am trying to configure a delta plane in elevon configuration. As a start I used a model configuration I found here, wing_elevons.ini, which has a mix with FMODE switch to realise a 3 step dual-rate. The problem I have is that I can't get both the elevator and aileron function corectly. Either I can get the elevator working correctly or the ailerons but not both at the same time. I have the atached the model configuration file and as it is now the elevator responds correctly but the ailerons wrong way around. Could anybody have a look at it and give me some clue what I should adjust to get both functions to work correctly?
Last edit: 07 Oct 2013 16:07 by EduardS.
07 Oct 2013 16:45 - 07 Oct 2013 16:49 #14310
Replied by vlad_vy on topic Help needed with delta plane model configuration.
Most likely you need reverse one of elevon channels at channel properties. This is due to the arrangement of servos.
Last edit: 07 Oct 2013 16:49 by vlad_vy.
- sbstnp
08 Oct 2013 01:41 #14313
by sbstnp
Devo 10 + 4in1
Spektrum Dx9
FrSky Taranis + TBS Crossfire
Replied by sbstnp on topic Help needed with delta plane model configuration.
Vlad is right.
Reverse ELE, check, revert to normal if not working.
Reverse AIL, check, revert to normal if not working.
Revese both and if still not working post a pic of your setup.
Devo 10 + 4in1
- EduardS
08 Oct 2013 10:24 #14334
by EduardS
Replied by EduardS on topic Help needed with delta plane model configuration.
Thanks, will try this and let you know. I tried to reverse ELE and AIL but not both at the same time.
08 Oct 2013 11:13 - 08 Oct 2013 11:26 #14335
In your model2.ini file is missing page 6 for ch3 mixer.
Corrected version
Also, max scale can't be more than 60%. After mixing two inputs (ELE+AIL) with max travel it will be 120% servo travel. You need scales: 33%, 50%, 60%.
Corrected version
Corrected version
Corrected version
Last edit: 08 Oct 2013 11:26 by vlad_vy.
- EduardS
08 Oct 2013 12:01 #14336
by EduardS
Thanks Vlad. I will try these out this evening after work.
- EduardS
08 Oct 2013 21:09 - 08 Oct 2013 21:10 #14361
by EduardS
Okay, thanks to you guys I figured out what was wrong. I had to reverse scalar on all AIL and !AIL input. Now I use model3.ini from Vlad, reversed the scalars of the AIL and !AIL input and all works fine. Thanks for the help Vlad and sbstnp, now I know a little more how to program Deviation.
Last edit: 08 Oct 2013 21:10 by EduardS.
09 Oct 2013 04:15 #14368
Replied by FDR on topic Help needed with delta plane model configuration.
Probably you could simply reverse the sources to !AIL and AIL (instead of AIL and !AIL with reversed scalars)...
- EduardS
09 Oct 2013 19:41 #14393
by EduardS
You are quite right FDR, I just tried is and it has the same effect. Thanks for letting me know.
10 Oct 2013 11:14 #14425
Probably you could simply swap servo connection to Rx CH2 and CH3.
- EduardS
10 Oct 2013 11:32 - 10 Oct 2013 11:32 #14430
by EduardS
I did try that Vlad, but that didn't work.
Last edit: 10 Oct 2013 11:32 by EduardS.
- sbstnp
10 Oct 2013 15:51 #14457
by sbstnp
Devo 10 + 4in1
Spektrum Dx9
Post a pic of your setup. You must be doing something wrong if you performed all the previous steps correctly, sorry.
Devo 10 + 4in1
- EduardS
10 Oct 2013 16:15 - 10 Oct 2013 16:23 #14462
by EduardS
It's working now, so why am I doing something wrong? My previous remark only addressed the suggestion of Vlad to swap the servo connectors from AIL and ELEV on the receiver. This didn't work, but the other suggestions did.
My setup is a pnf Sonic64 from Hobbyking. Can't do much wrong there.
Last edit: 10 Oct 2013 16:23 by EduardS.
- sbstnp
10 Oct 2013 16:42 #14466
by sbstnp
Devo 10 + 4in1
Spektrum Dx9
Apologies if it's working
I'm kinda of in a hurry lately, too much going on, I probably just skimmed the posts and assumed problem was not solved
EduardS wrote: It's working now, so why am I doing something wrong? My previous remark only addressed the suggestion of Vlad to swap the servo connectors from AIL and ELEV on the receiver. This didn't work, but the other suggestions did.
Devo 10 + 4in1
- EduardS
10 Oct 2013 17:19 #14472
by EduardS
No problem sbstnp, you were just trying to help.
- Teemu147
01 Jun 2014 15:43 #23825
by Teemu147
Replied by Teemu147 on topic Help needed with delta plane model configuration.
How i can chance throttle to channel 3 and elevator to channel 1 on this configuration? also can elev and aile dual rates have own switches?
01 Jun 2014 17:10 #23827
Replied by PhracturedBlue on topic Help needed with delta plane model configuration.
You need to go to the mixer page, then the Re-order menu. On a Devo10 you get there by holding the R+ button. On the Devo8 it is the button at the top with 2 arrows.
Then move 1 down one-position and 3 up two-positions. the order should now be:
3
2
1
4
5
When you finish, the channels will be swapped.
3
2
1
4
5
- Teemu147
02 Jun 2014 12:08 #23847
by Teemu147
I have devo 10 but i dont get to re order menu. I go to main menu-> model menu -> mixer -> and hold R button right bottom corner of transmitter. Nothing hapens?
02 Jun 2014 16:51 #23850
What version of Deviation are you running?
I forgot that this capability was only added after 4.0.1 (for the Devo10...Devo8 had it in 4.0.1)
You either need to:
a) upgrade to the nightly build to get this capability
b) write down all the parameters for channels 1 and 3, then change the values by hand
c) provide your model.ini and I can swap the channels for you.
You either need to:
- aritchie71
25 Feb 2015 18:18 #29114
by aritchie71
Can someone please tell me which parts of the file I would need to change to make the ailerons work the right way round, I am very very new to this programming stuff, I have a plane sitting waiting to get into the sky but don't trust myself to remember that the ailerons are reversed!
Regards,
Andy.
Replied by aritchie71 on topic Help needed with delta plane model configuration.
FDR wrote: Probably you could simply reverse the sources to !AIL and AIL (instead of AIL and !AIL with reversed scalars)...
Regards,
Andy.
Time to create page: 1.429 seconds
- Help needed with delta plane model configuration.
