Devo7E pooched??
03 Nov 2013 05:30 #15275 by Shawzie
Devo7E pooched?? was created by Shawzie
Long story short,bought a super cp with devo7e have had it for 3 days,everything worked great but wanted to use my tx for my Mcpx as well,downloaded deviation and didn't really like it,went to return original firmware and now my screen has large blocks on it and I can't read it at all!! I've tried 10 times to switch it back to the original but it won't go back,then I figured I would just put deviation back on and live with that,all I get for deviation now is the picture of the helicopter!!!! 3 days and my TX is not useable :(:( anyone help me please!!! Read the FAQ and nothing seems to work.
03 Nov 2013 06:18 - 03 Nov 2013 06:20 #15277 by vlad_vy
Replied by vlad_vy on topic Devo7E pooched??
Back to original firmware:
1) Download fresh firmware archive from Walkera
2) UPGRADE firmware
3) UPGRADE library
Back to Deviation:
1) UPGRADE firmware
2) Format Tx drive
3) Write Tx filesystem
4) Copy to Tx filesystem 'protocol' folder from firmware archive
Last edit: 03 Nov 2013 06:20 by vlad_vy.
03 Nov 2013 06:36 #15280 by Shawzie
Replied by Shawzie on topic Devo7E pooched??
Ya I've done that 10 times,I go to the walkera site and download the Devo7E firmware version 0.2,then upgrade it and its still the same?? When I go to upgrade in the library it says it can't read the data??
03 Nov 2013 06:48 #15281 by vlad_vy
Are you shure you do 'UPGRADE AND VERIFY' library? If you did 'UPLOAD' library, you destroyed library file.
03 Nov 2013 06:54 #15282 by Shawzie
Ya,I've never done upload,it's always been upgrade,when I try it in library it says "unable to find data for that device/target from file" Now all my files in deviation say cannot read,files are corrupt WTF???? Should have just left everything alone now I'm screwed and have to buy a new one hahahahaha.
03 Nov 2013 07:15 #15283 by FDR
Replied by FDR on topic Devo7E pooched??
Follow Vlad's instruction step by step strictly, and it will work.
You upgrade the library on the library tab, not on the firmware tab...
03 Nov 2013 07:17 #15284 by vlad_vy
Try download fresh archives, probably files are corrupted.
03 Nov 2013 07:39 #15285 by Shawzie
This is what it's doing in library. I can't insert new archives in deviation either cause it says "cannot read files,files corrupt" so when I go to put the new ones in they won't go. I tried making a new folder in removable disc and it didn't work either.
03 Nov 2013 07:42 #15286 by Shawzie
03 Nov 2013 07:52 - 03 Nov 2013 07:56 #15287 by vlad_vy
At Library tab you selected firmware file, not library file. You have to select 'DEVO-7E Lib v0.1.dfu'.
With Deviation firmware, you need first format removable drive, it is corrupted after flashing original firmware.
Last edit: 03 Nov 2013 07:56 by vlad_vy.
03 Nov 2013 08:06 #15288 by Shawzie
That worked!!! Thank you so much my friend!!!! I owe you!!! I'm just going to leave it the way it is. Thank you once again.
Time to create page: 0.317 seconds
