range problem with 7e and deviation
- thefreak1980
16 Nov 2013 21:21 - 16 Nov 2013 21:23 #15630
by thefreak1980
range problem with 7e and deviation was created by thefreak1980
Yesterday i flashed my 7e with Deviation 3.0. Everything worked flawlessly for me. Today I made some tests und recognized that the range is very low. Not even 10 meters, bound to super CP.
In the Main Display it shows a power output of 150 mW. But in the Model setup menu I am not able to change the power. When I click on the field for changing power there is only "standard" set. Then I was looking for the model inis in fielsystem , opens with text editor and there is 10 mW set. What can I do to increase power output?
Last edit: 16 Nov 2013 21:23 by thefreak1980.
17 Nov 2013 09:07 #15644
Replied by rbe2012 on topic range problem with 7e and deviation
There is a hardware modification you can do even if you don't have years of experience with electronic components.
You can read it here (please read the whole thread before starting):
Devo7e: Diode mod for better reach
- thefreak1980
17 Nov 2013 11:19 #15650
by thefreak1980
Replied by thefreak1980 on topic range problem with 7e and deviation
but on stock firmware range was higher
17 Nov 2013 17:20 #15657
Replied by FDR on topic range problem with 7e and deviation
AFAIK it should ignore any tx power settings, if your tx.ini disables the power amplifier like that:
...but try to edit the model config file with a proper text editor (like Notepad++) to 150mW, and see if that help.
[modules]
has_pa-cyrf6936=0...but try to edit the model config file with a proper text editor (like Notepad++) to 150mW, and see if that help.
- thefreak1980
18 Nov 2013 11:14 #15674
by thefreak1980
OK, tried this:
[modules]
has_pa-cyrf6936=1
Now iam able to set to output. But still on 150mW very low range (about 5 meters). Went back to stock FW and the same problem. Later try with DSM2/X receiver
[modules]
has_pa-cyrf6936=1
18 Nov 2013 11:31 #15675
No, you shouldn't enable the power amplifier if you didn't do the diode mod!
I suggested to modify the model.ini to contain 150mW as the tx power...
However if the stock fw's range is bad too, than there should be some hardware problem. ..
Have you installed additional RF modules?
Have you opened up the tx at all?
- thefreak1980
18 Nov 2013 15:53 #15683
by thefreak1980
Tada
OK guys, sounds crazy, but replaced batteries and now full range. Went back to deviation 3.0 and everything is fine. Thanks
- thefreak1980
18 Nov 2013 16:11 #15684
by thefreak1980
Maybe soon I will apply the power mod. I like the tiny stile of the 7e. It's perfect for my T-Rex 250. As standard I use a DX8. Tiny Models,tiny transmitter
- domcars0
20 Nov 2013 17:07 #15707
by domcars0
Replied by domcars0 on topic range problem with 7e and deviation
Put the antenna INTO the radio to have a better range.
If the antenna is parallel to the top of the TX, the range is better than if the antenna is pointed in direction of the model.
(Sorry for my frenglish
Time to create page: 0.516 seconds
- range problem with 7e and deviation
