devo 10 nRF24L01+ Hisky
27 Dec 2013 19:00 #17139 by HappyHarry
Replied by HappyHarry on topic devo 10 nRF24L01+ Hisky
thanks victzh, and enjoy your holidays :)
re the ht8 3 modes, those are input modes to deal with different company channel orders, so perhaps matching what order the ht8 outputs or a proper hisky tx outputs would be the correct order? but iirc deviation uses the same channel order as futaba? all that needs to be done to correct this is for the cyclic channel positions to be rotated 1 position clockwise, though how this would be handled in the code I leave up to your much better knowledge :)
yes the fbl80 should suit your needs,
  • ovres
  • ovres's Avatar Topic Author
  • definitely in control ;)
27 Dec 2013 21:11 #17154 by ovres
Replied by ovres on topic devo 10 nRF24L01+ Hisky
HappyHarry wrote: ovres VCC and CE from the module go to VDD on the TX, and CSN on the module goes to either TMS or TCK depending if this is your first module or second, if it's the first module you've added then use TMS, otherwise use TCK
Thank you Phil it works now. :)
28 Dec 2013 07:51 - 28 Dec 2013 07:56 #17255 by Daryoon
Replied by Daryoon on topic devo 10 nRF24L01+ Hisky
When using the HT8 module with my Turnigy 9x, I had to swap the cyclic channel around.
The Turnigy 9x uses Futaba's channel order of
A
E
T
R
In my output mix, I had to define:
CH1: CYC2
CH2: CYC1
Likewise, for Deviation HiSky, the order I used is
CH1: CYC2
CH2: CYC1
So I find Deviation HiSky and Turnigy 9x consistent with each other.
That said, back when I was using Deviation with PPM output and the HT8 module...
CH1: CYC1
CH2: CYC2
Last edit: 28 Dec 2013 07:56 by Daryoon.
20 Oct 2014 12:25 #26113 by ashsys
Replied by ashsys on topic devo 10 nRF24L01+ Hisky
ovres wrote: I can't get the module installed properly. The red numbers go from module to TX. The yellow numbers I do not know where to go.
guess your modded devo is now working great.. I am trying to install nrf24l01 in my devo 10 as well..
Could you please map all connections. 2,3,4,5 as well. where it goes to Tx ?
Complete connection diagram would be awesome if you can.
20 Oct 2014 16:47 #26114 by aMax
Replied by aMax on topic devo 10 nRF24L01+ Hisky
Time to create page: 0.228 seconds
