7E installation problem
- VTdev
26 Jan 2014 20:08 - 26 Jan 2014 20:10 #19207
by VTdev
7E installation problem was created by VTdev
deviation-devo7e-v4.0.1-6a63c8e.
("new" below means something has changed
1.) Start up: message "Bad/missing protocol modules!"
2.) Opened Model 1, changed Model type to Plane
3.) new: Tx is defaulting to 10 mW (was 150 but 10 is correct -- no power mod)
4.) Protocol selected DSM2
5.) new: Re-Init is the next action (used to be "Bind")
6.) new: # Channels is 12 (I think it used to be 7?)
7.) Mixer GuI left as Advanced
8.) Went to TX menu, Tx config
9.) Stick Mode is Mode 2 (default)
10.) Calibrated sticks.
11.) Went to Channel Monitor
12.) Channel monitor shows left stick vert. assigned to CH3, Right stick vert. assigned to CH1
13.) Switching off Tx, and switching on again message: CH1 is 0% safe value = -100% (repeated twice) then the Bad/Missing modules message.
Notes:
To see if the protocol modules had somehow not transferred properly I opened the Protocol folder on the Tx and counted 16 modules present. This is the same as found in the build.
I then deleted the entire protocol directory on the Tx, and loaded a fresh version from the build. Tx drive was properly unmounted. Was able to reproduce the the above.
I then checked the Mixer
1-THR was mixed to ELE, and 3CH-ELE was mixed to THR
I then changed the Model type to Heli
No change in channel assignments
Notes:
Last edit: 26 Jan 2014 20:10 by VTdev.
- VTdev
26 Jan 2014 20:17 - 26 Jan 2014 20:20 #19211
by VTdev
Replied by VTdev on topic 7E installation problem
Here's a "good" model.ini for the plane version of above. Created in the v4.01 official release version of deviation.
Last edit: 26 Jan 2014 20:20 by VTdev.
- HappyHarry
26 Jan 2014 20:21 #19212
by HappyHarry
Replied by HappyHarry on topic 7E installation problem
with the 7e you always have to replace the protocols folder with the one that came in the build you are installing, hence you receiving the bad/missing protocols message
- VTdev
26 Jan 2014 20:28 - 26 Jan 2014 20:29 #19215
by VTdev
Harry I replaced everything when I started testing, including the protocols folder. The TX was blank. I moved the entire build in.
I also copied the protocols folder a second time -- and noted that above. No change.
Last edit: 26 Jan 2014 20:29 by VTdev.
- robca
26 Jan 2014 20:35 #19216
by robca
Replied by robca on topic 7E installation problem
I tested HappyHarry's latest build and the protocols are working fine after copying them from the ZIP to the Protocols folder (I forgot to do it originally, got the same message, copied them, message gone)
- VTdev
26 Jan 2014 20:41 #19217
by VTdev
Okay wording looks slightly different -- Harry said replace protocols folder robca said copying protocols -- does that mean individual files copy vs folder w/files copy?
I'll try copying the files rather than the folder with files......
- VTdev
26 Jan 2014 20:53 #19219
by VTdev
Copied individual files. No difference.
- VTdev
26 Jan 2014 20:57 #19220
by VTdev
Okay, I'm going to wipe the Tx again. Unzip the build again and copy it over again.....
- HappyHarry
26 Jan 2014 20:58 #19221
by HappyHarry
files/folder with files it makes no difference, just be sure to use the protocol modules from the exact build you are installing, not just from another 4.0.1 build but the exact build (6a63c8e in this case)
- robca
26 Jan 2014 21:01 #19222
by robca
When you flash a new build of Deviation, usually your filesystem doesn't change. So I usually just copy over the new files. For the protocol directory, since the files are always the same 16 file, I just copy them over the old ones, replacing them
I flashed a lot of time, never had to wipe the Tx (not that it would hurt, mind you
, just an extra step I was lucky not to have to do)
- VTdev
26 Jan 2014 21:06 - 26 Jan 2014 21:09 #19223
by VTdev
robca, I wiped it to eliminate any question in testing.
Just wiped it again. Unzipped the build. Copied the build to the Tx (except .dfu and dev zip). Unmounted the Tx. Turned it on and got the Bad or missing protocol message immediately.
I got the build here:
www.deviationtx.com/forum/builds/2661-7e...timer-weekly-updates
I used the zipped file attached to the first post there.
Last edit: 26 Jan 2014 21:09 by VTdev.
26 Jan 2014 21:13 #19225
Replied by rbe2012 on topic 7E installation problem
VTdev,
it is more likely that this message is a result of an active model config which defines a protocol what is not activated in the hardware.ini. Please take a look at the hardware.ini and the modelXX.ini you're trying to load.
- VTdev
26 Jan 2014 21:13 #19226
by VTdev
If Harry didn't wipe the Tx either, then maybe that is the difference.
Or if you both didn't use the same build file zip that I did, than that might be a difference.
Only two I can think of....
- VTdev
26 Jan 2014 21:17 #19228
by VTdev
rbe, attaching both here. They were received in the build zip.
- HappyHarry
26 Jan 2014 21:23 - 26 Jan 2014 21:26 #19230
by HappyHarry
it's my build file your using so of course i used it, and yes i wiped the tx as i always do when testing a new build.
i just re wiped the tx and used my build to flash and copied the filesystem accross and it worked fine.
you must be doing something wrong in your process
maybe PB or FDR if you read this could move these install posts to another thread, as there is no need to fill the channel switching testing thread with install issues
Last edit: 26 Jan 2014 21:26 by HappyHarry.
- VTdev
26 Jan 2014 22:25 #19233
by VTdev
I've just wiped the Tx and reinstalled the official released version, and no Bad/missing protocol message. Starts up fine.
So I wiped again and reinstalled the new build, one more time. I used exactly the same method as the above official release (except for the fact that the new build included a hardware.ini -- which was copied across) and on turning the Tx on, had exactly the same Bad/Missing protocol message as before.
- HappyHarry
26 Jan 2014 22:42 #19234
by HappyHarry
i don't know what else to say or suggest, i have re-downloaded the file from the site to make sure there wasn't an issue when uploaded, extracted it, flashed the dfu, erased the usb drive contents and copied the new extracted filesystem across. i have done this in windows and repeated it again in linux, and it works perfectly in both OS's. Also as you have seen other users are having no problems with the file so i'm afraid that using a simple method of elimination that leaves your method/your tx/your computer as the problem.
please tell me you are flashing the new dfu and not just copying across the filesystem?
- VTdev
26 Jan 2014 22:43 #19235
by VTdev
Wiped, did the official version again. no problems.
Wiped, did the new build again, same old problem.
Deleted the protocol directory.
Copied it to the Tx again.
Same problem.
Any suggestions?
Same problem.
Any suggestions?
- VTdev
26 Jan 2014 22:45 #19236
by VTdev
I am copying it across the filesystem. With both the official version and the new build.
Why would they vary?
- HappyHarry
26 Jan 2014 22:50 - 26 Jan 2014 22:51 #19237
by HappyHarry
flash the new dfu with dfuse, it doesn't install the core firmware just by copying it across with the filesystem, please go read the manual on how to install deviation, you need to follow this method every time you want to install a newer version
Last edit: 26 Jan 2014 22:51 by HappyHarry.
Time to create page: 0.131 seconds
- 7E installation problem
