What RX for DEVO8s? DSSS vs DMSX
- ricksonchow
12 Feb 2014 08:40 #20172
by ricksonchow
What RX for DEVO8s? DSSS vs DMSX was created by ricksonchow
As I have used the Deviation 4.0.1 firmware, both protocols are supported by my TX now. I am considering the DEVO RX802 (DSSS) and the Orange R800x (DSMX). Both are around similar price range, so just want to know which one will be better in terms for range and stability with my Devo 8S. Thanks for advance:)
12 Feb 2014 08:51 #20173
Replied by vlad_vy on topic What RX for DEVO8s? DSSS vs DMSX
I think they both have same range, but DSMX is more immune to interference.
If you need 11ms for servos, you can use DEVO RX802 (selected by button in Rx).
image.helipal.com/helipal-walkera-rx802-manual.pdf
- HappyHarry
12 Feb 2014 12:09 #20183
by HappyHarry
Replied by HappyHarry on topic What RX for DEVO8s? DSSS vs DMSX
dsmx 11ms is the size of the packet transmission framewidth between TX and rx, why would servo's require an 11ms framerate?
12 Feb 2014 12:48 #20184
Rx PWM output 22ms for analog and digital servo
Rx PWM output 11ms for digital servo only
DSMX 11ms only applies to servo ports AILE, ELEV, and AUX1 in early radios (thru DX8) and adds RUDD in DX10t and above. The other channels are transmitted at 22ms refresh rates.
- HappyHarry
12 Feb 2014 13:42 #20186
by HappyHarry
yes I know that thanks, it was initially aimed at eccpm heli flyers mostly. I just wondered why you said 11ms if the servos need it, as no servo's actually need 11ms framewidth.
- ricksonchow
12 Feb 2014 15:49 #20198
by ricksonchow
Replied by ricksonchow on topic What RX for DEVO8s? DSSS vs DMSX
Thanks for everyone's in put. As I am going to use it on a plane so I do not need super quick respond time. But what make me concern is the reliability of my Deviation DEVO 8S. As it is designed to use with DSSS, I am not sure if the DSMX will be as stable as the DSSS or the is no difference (only focusing on TX)
- sbstnp
12 Feb 2014 15:55 - 12 Feb 2014 15:57 #20199
by sbstnp
Devo 10 + 4in1
Spektrum Dx9
FrSky Taranis + TBS Crossfire
Replied by sbstnp on topic What RX for DEVO8s? DSSS vs DMSX
DSSS is Direct Sequence Spread Spectrum, it's a modulation technique over the entire 2.4Ghz band. It's not an attribute of the protocols but of the underlying hardware (or the way it's configured to transmit).
Both Devo and DSMX are DSSS/FHSS basically, DEVO works on 3 fixed channels while DSMX hops between (iirc) 23 channels.
Hope I cleared things up (Wikipedia is your friend).
Devo 10 + 4in1
Last edit: 12 Feb 2014 15:57 by sbstnp.
- Fishfiend
12 Feb 2014 21:47 #20207
by Fishfiend
Replied by Fishfiend on topic What RX for DEVO8s? DSSS vs DMSX
Hey Rick, Don't sweat it I get full control at over 20m at the lowest power settings on both my 12s and 8s and I'm using them on my 700e and new gaui nx4
and thats on a dsmx ar7200bx, never a glitch on either of them. Stick them on your planes and I can fly them too when you come back
long live the jets...and team tornado
- ricksonchow
13 Feb 2014 03:16 #20216
by ricksonchow
Thanks for replying and yes, you really cleared things up
So seems a DSMX receiver will be a better choice!
- ricksonchow
13 Feb 2014 03:26 #20217
by ricksonchow
Thanks Greg! Yeah Walkera rules! I love my 8S a lot
I am going to get the DSMX receiver and stick it into a plane. I will swap all planes into my 8S as well. Miss u a lot! Wish I can come back to fly again at Croydon! Yeah team tornado !
Time to create page: 0.617 seconds
- What RX for DEVO8s? DSSS vs DMSX
