good wire deal
19 Feb 2014 16:51 #20585 by Leather Lung
good wire deal was created by Leather Lung
m.banggood.com/?t=showDetailInfo&products_id=75612
Good wire for wiring in modules, ie A7051 in a devo 10?
19 Feb 2014 17:05 #20586 by Leather Lung
Replied by Leather Lung on topic good wire deal
19 Feb 2014 17:13 #20587 by SadSack
Replied by SadSack on topic good wire deal
Wire generally is good but for your needs too thick/stiff and left in ribbon form you'll likely damage solder pads on module.
You'd be better with this www.banggood.com/10-X-15cm-60-Cores-Serv...aba-JR-p-909171.html servo leads.
Module looks fine
Item Name: A7105 Wireless RF 2.4GHz Transceiver Module 3.3V Power Supply Module
Output Power: 17dBm
Emission Current: 120mA << there are two version of this module and 120mA is the better one.
Receive Current: 23mA
Receiver Sensitivity: -102dBm@250Kbps
Weight: 3g
19 Feb 2014 21:21 #20608 by Leather Lung
2.4GHz NRF24L01P + PA + LNA Long Distance RF Wireless Module V3.1
Thanks, I was.unable to open the url for the wire. How is this for the nrf 24 mod? Unsure about the gold antenna attachment on it though.
19 Feb 2014 21:23 #20609 by Leather Lung
SadSack wrote: Wire generally is good but for your needs too thick/stiff and left in ribbon form you'll likely damage solder pads on module.
Module looks fine
Output Power: 17dBm
This it?
Weight: 3g
19 Feb 2014 21:40 #20610 by hogan
Replied by hogan on topic good wire deal
Just get an old mouse and get the wire from it, worked perfectly for me. Since then, I think I have been hoarding them as I run across them.
19 Feb 2014 21:47 #20611 by Leather Lung
nice, how many strands are in the mouse?
19 Feb 2014 21:57 #20614 by SadSack
it will work but you need to deal with that SMA connector and would be so simple to remove. www.aliexpress.com/item/Free-Shipping-nR...1000m/709420583.html this is simple to remove. I replaced mine with www.aliexpress.com/snapshot/309290015.html and i can use www.aliex
press.com/snapshot/308280971.html
19 Feb 2014 22:06 - 20 Feb 2014 01:09 #20615 by Leather Lung
The one from alexipress would be better? I don't understand the antenna looking attachment, and what I would do to remove it out leave it be. Thanks for the help
What is the sma conne tor? How to remove
Last edit: 20 Feb 2014 01:09 by Leather Lung.
20 Feb 2014 02:20 #20624 by hogan
Leather Lung wrote: nice, how many strands are in the mouse?
Mouse cable had 4 wires. My biggest amount came from the old serial cable from my old printer. 23 wires 8 feet long each.
20 Feb 2014 03:31 #20630 by Shanman3us
Replied by Shanman3us on topic good wire deal
Leather Lung wrote: The one from alexipress would be better? I don't understand the antenna looking attachment, and what I would do to remove it out leave it be. Thanks for the help
goo.gl/twkE6f
22 Feb 2014 05:03 #20727 by ztech
Replied by ztech on topic good wire deal
I like using a combination of standard #24 solid core phone wire and cat5 for the colors. Solid core routes better than stranded and is easier to solder, red - green, yellow - black, and the orange, blue from the cat5 to match the colors from the hackmods pinout.
22 Feb 2014 07:28 #20731 by suzali
Replied by suzali on topic good wire deal
Leather Lung wrote: 2.4GHz NRF24L01P + PA + LNA Long Distance RF Wireless Module V3.1
is this the same as A7105 ???
22 Feb 2014 15:19 #20743 by Leather Lung
ztech wrote: I like using a combination of standard #24 solid core phone wire and cat5 for the colors. Solid core routes better than stranded and is easier to solder, red - green, yellow - black, and the orange, blue from the cat5 to match the colors from the hackmods pinout.
I'm sorry, when you say cat 5 what do you meam? #24 solid vote phone wire when should I use this type. Thanks
23 Feb 2014 06:19 #20780 by Leather Lung
Thanks got some cat 5e and cat 6 for cheap. I'm learning thanks to you guys.
26 Feb 2014 02:19 #20872 by Leather Lung
When soldering this type of small wire together, what do you guys use for insulation? Do they make shrink wrap that small or is there a lighter better way?
Time to create page: 0.701 seconds
