Phoenix v5 is out and breaks PPM again.
26 Feb 2014 19:01 #20898 by Hexperience
Phoenix v5 is out and breaks PPM again. was created by Hexperience
So I upgraded to Phoenix 5 and lost channels 7 and 8 again. This time making a new model and resetting up doesn't fix it. It doesn't seem to be a deviation problem because on Real Flight 6.5 all channels work....
Anyway, just a warning if you are thinking of upgrading to Phoenix 5.
27 Feb 2014 01:36 #20911 by jazzjohn
Replied by jazzjohn on topic Phoenix v5 is out and breaks PPM again.
Thanks for the warning. After reading all the negative comments about it on HF, it seems like it's best to stick with 4 for a while. Just like when Windows 8 came out, my first thought was,"what were they thinking?"
28 Feb 2014 17:29 #20983 by Joshua
Replied by Joshua on topic Phoenix v5 is out and breaks PPM again.
Phoenix V5 works fine with my Devo8S and latest software.
01 Mar 2014 13:03 - 01 Mar 2014 13:04 #21019 by Hexperience
Replied by Hexperience on topic Phoenix v5 is out and breaks PPM again.
I'm using a devo12. I know there is some difference in the ppm out on the trainer port for the devo12 vs the devo8 but I don't know what the differences are.
I don't think its a deviation problem, I use the same model in my devo12. Simple 8 channel ppm out. On Real flight all 8 channels. On phoenix 5 only 6. I had this problem on phoenix 4 but somehow starting over with a fresh model and fresh config in phoenix fixed it.
Oh well, real flight seems to be working well and in 6.5 the heli physics are great.
I'll try my er9x radio on phoenix and see what happens.
Last edit: 01 Mar 2014 13:04 by Hexperience.
