Devo 7E and 10 white not recognized by Dfuse
26 Mar 2014 12:02 #21850 by Golddigger
Hello everybody
I would like to install the Deviation software on one of my Devos (Devo 7e and the Devo 10 White).
The problem is that non of them is recognized.
Just to make shure that im doing everything right: I plug in the Up02 cable, it installs the drivers (on Windows 8 I did it myself). Then I plug in my Tx, press "ext" and press the power button--> Not recognized by Dfuse.
I already tried:
-Newer and older versions of the Dfuse
-Starting Dfuse in compatibility mode (Xp service pack 3/Windows 7)
-Tried it on 3 diffrent Pc's (2 with Windows 7 and 1 with Windows 8)
- Tried several USB-Ports
- Restarted Pc
Hope somebody knows what could be the problem or what Im doing wrong.
Regards Golddigger
(and sorry for grammar mistakes)
26 Mar 2014 12:18 #21852 by HappyHarry
Replied by HappyHarry on topic Devo 7E and 10 white not recognized by Dfuse
you use a standard USB cable to connect the TX to the PC, you don't use the up02 at all for tx's.
26 Mar 2014 13:36 #21856 by Golddigger
Replied by Golddigger on topic Devo 7E and 10 white not recognized by Dfuse
Emm no?
I think u have to use the Up02 USB cable?
26 Mar 2014 15:30 #21862 by PhracturedBlue
Replied by PhracturedBlue on topic Devo 7E and 10 white not recognized by Dfuse
The UP02 cable is for the Devo7 only because that radio does not have a USB port. For the Devo7e and Devo10 (and all radios supported by Deviation) you use a standard USB cable (that should have come with your radio)
26 Mar 2014 16:28 #21864 by Golddigger
:blink: :pinch: :blink:
Will try it as soon as im Home. Thx for helping. Hope to get it work now.
05 Apr 2014 20:02 #22154 by adolfotregosa
Replied by adolfotregosa on topic Devo 7E and 10 white not recognized by Dfuse
Hi.
Did you manage to install deviation on the devo 10 white?
Is it working correctly?
Thank you
05 Apr 2014 21:29 #22155 by Bollis
Today I installed the deviation firmware on my devo 10 white without any problems .
05 Apr 2014 21:33 #22156 by adolfotregosa
Great. I'm getting one during next couple of weeks tops and would like to try out the deviation work of art. Thank you for the confirmation.
Thank you
12 Apr 2014 20:38 #22369 by Golddigger
I could easily install Deviation with the normal USB cable :cheer:
Works fine on the Devo 10 white and my Devo 7E. Thanks for helping btw ;)
Time to create page: 0.108 seconds
