Devo 10 DSM2 Bind issue
- Jman841
03 Apr 2014 06:55 #22073
by Jman841
Devo 10 DSM2 Bind issue was created by Jman841
I have been using a modded Devo 7e running Deviation flying my Gaui X3 with Lemon Rx Sat recievers on DSM2 with no issue.
I loaded the model file from my Devo 7e to my Devo 10 and reworked a few things (TH, FMODE, etc). Except now I can not bind the Devo 10 to my Gaui X3.
Any Ideas what I am doing wrong?
I have it set at DSM2 with NONE for the fixed code setting.
- blackmoon
03 Apr 2014 11:06 #22074
by blackmoon
Replied by blackmoon on topic Devo 10 DSM2 Bind issue
I don't know if this is what you did, it's not clear from what you wrote, but a sat needs to be bound whit a conventional RX. The devo10 and 7E have different TX id so you need to re-bind with a RX for this to work.
If it's what you did, I'm as puzzled as you.
- Jman841
03 Apr 2014 19:21 #22089
by Jman841
Replied by Jman841 on topic Devo 10 DSM2 Bind issue
I am running DSM2 Sat's into a Mini V-Bar. I am puzzled. I will try resetting the mini-vbar later and try again but if the Devo 7e is binding no problem it leads me the believe it is the Devo 10.
My Devo 10 binds to my V120D02s on Devo protocol with no issue.
- Jman841
04 Apr 2014 06:00 #22105
by Jman841
Got it working,
Had to reset the V-Bar in Vstabi to accept the new Tx. It must define a freq code and use it every time after the initial setup with that freq code.
Time to create page: 0.031 seconds
- Devo 10 DSM2 Bind issue
