Devo12s Battery Question
- unclecrash
09 Apr 2014 03:38 #22254
by unclecrash
Devo12s Battery Question was created by unclecrash
Wondering how low can I run the battery on the tx before I would loose control,or a safe cutoff voltage to stop flying or set a warning beep. Thanks Pharctured Blue I got the tx going again.
- Kdean
09 Apr 2014 03:41 #22255
by Kdean
Replied by Kdean on topic Devo12s Battery Question
I set mine to 3.9 but you could probably run it down to 3.7 before you start getting performance degradation. I have not tested it, so i play it safe.
- unclecrash
09 Apr 2014 04:16 #22256
by unclecrash
Replied by unclecrash on topic Devo12s Battery Question
Ok thanks alot what kind of run time should I expect out of a full charge run down to 3.9v
- Kdean
09 Apr 2014 04:38 #22258
by Kdean
Ok, just checked my 12s, (it was in storage now that I use the 8s most of the time). I have my battery alarm set at 3.80.
Like i said before, i did not test it, so I cant really say how long a full charge would last. But i've never had it lose enough power, during a regular day of flying, to cause any concern. Most times charging every other weekend, depending on if I had to do any setups through the week.
- unclecrash
09 Apr 2014 04:55 #22260
by unclecrash
OK I will keep that in mind, Thanks again.
- Devo12s Battery Question
