Switch / stick warning at startup
12 Apr 2014 21:37 - 15 Apr 2014 19:14 #22370 by lcn
Hello
I would to set a stick warning on throttle channel if the value is not at the minimal value when powering on the Devo.
How should I configure an alert box and a buzzer setting if throttle value is larger than a defined value .
Many thanks for your help,
Last edit: 15 Apr 2014 19:14 by lcn.
12 Apr 2014 21:44 #22372 by PhracturedBlue
Replied by PhracturedBlue on topic Switch / stick warning at startup
default models already have this feature.if you power your tx up with throttle not at minimum it should give you a warning until you fix it.
This is set in the model.ini via:
[safety]
Auto=min
You can additionally add more constraints for sticks and switches, bvut the Auto setting verifies that the throttle channel is at minimum value on power-on.
16 Apr 2014 17:22 #22470 by lcn
Replied by lcn on topic Switch / stick warning at startup
Thanks,
I added these lines into model *.ini file.
Now, when the Devo 12s starts it shows a safety windows that informs :
Ch3 is -3%, safe value = -100%
But ... Ch3 is Elevation on my Devo12S. :unsure:
I need the check on Throttle right hand side stick.
Stick mode is indeed set to "Mode 2" in the configuration because i using this mode.
This means Throttle is the right stick, the Devo12s looks to see it differently.
16 Apr 2014 17:24 #22471 by PhracturedBlue
Mode 2 has throttle as the left stick:
www.ef-uk.net/manuals/mc-20/rc-control-modes.jpg
18 Sep 2014 01:30 - 18 Sep 2014 01:53 #25711 by DonKracho
Replied by DonKracho on topic Switch / stick warning at startup
same issue for me. I'm using a Devo 8 with version 4.0.1
The setting
[safety]
Auto=min
seems to be related fixed to Ch3 and not the configured throttle channel!
I want to use the rudder on channel 3 and throttle on ch4 (MPX) and have to move the rudder in order to quit the safety screen.
Last edit: 18 Sep 2014 01:53 by DonKracho.
18 Sep 2014 06:51 #25715 by Arakon
Replied by Arakon on topic Switch / stick warning at startup
Change it to:
THR=min
21 Sep 2014 12:49 #25751 by DonKracho
Thx, "THR=min" did it for me.
Time to create page: 0.074 seconds
