Trouble with AUX7 potentiometer
- lcn
15 Apr 2014 19:13 - 15 Apr 2014 19:13 #22426
by lcn
Trouble with AUX7 potentiometer was created by lcn
Hello
I've assigned Channel 10 with AUX7 potentiometer.
I set it as 'Simple' and 1-to-1 and scale is 100
When I check this channel in 'Channel Monitor' the bar stays at 100% value even the potentiometer is been turned or not.
If the potentiometer is at its minimum value the bar goes to -100% but tiny move gets the bar back to 100%
Why the bar monitor does not reflect the position of the potentiometer from -100 to 100% ?
Thanks for your help
Last edit: 15 Apr 2014 19:13 by lcn.
15 Apr 2014 19:18 #22427
Replied by FDR on topic Trouble with AUX7 potentiometer
You have to calibrate the pots too with the stick calibration.
- lcn
15 Apr 2014 19:36 #22428
by lcn
Replied by lcn on topic Trouble with AUX7 potentiometer
Many thanks it solved the issue, I forgot to calibrate the knobs previously.
But, what are names for side potentiometers on Devo 12s , I can assign them to a channel
These haven't any name.
16 Apr 2014 03:32 - 16 Apr 2014 03:33 #22441
Replied by vlad_vy on topic Trouble with AUX7 potentiometer
You can check that at "Input Monitor" screen.
Last edit: 16 Apr 2014 03:33 by vlad_vy.
- unclecrash
16 Apr 2014 04:36 - 16 Apr 2014 04:49 #22444
by unclecrash
Replied by unclecrash on topic Trouble with AUX7 potentiometer
Last edit: 16 Apr 2014 04:49 by unclecrash.
Time to create page: 0.874 seconds
- Trouble with AUX7 potentiometer
