Sequential output channel signal by a switch?
22 Apr 2014 00:47 - 22 Apr 2014 03:45 #22644 by dc59
Is it possible to assign a switch(ex: mix/gear/fmode.....) which can output a channel signal sequentially?
output from A/B/C .... to G sequentially, not form A "Jump" to G
just like a pulse(programable)?
Last edit: 22 Apr 2014 03:45 by dc59.
23 Apr 2014 20:36 #22673 by FDR
I don't really understand what do you mean...
Could you describe it more?
24 Apr 2014 02:53 #22679 by dc59
Sorry for suck English.... :(
I want to set gear switch at channel 1,When I switch from Gear 0 to Gear 1,
Channel 1 can output point 1/A(0),point 2/B(0),point 3/C (+100),point 4/D (+100),point 5/E(0),point 6/F (0),point 7/G (0) step by step , like a pulse (0 -> 100 -> 0).
but now , I just can set Gear 0 = 0(Point 0/A) , Gear 1 = 100(point 3/C) ...
Thank you veay much.
24 Apr 2014 04:53 #22681 by Kdean
Maybe use the channel speed/delay???
25 Apr 2014 06:52 #22712 by dc59
Hi Kdean,
Thanks for reply.
I try to change channel speed and can't find any thing different .. :(
Would you please give me some hint?
17 Oct 2020 06:58 #76893 by Maco33
Hi boys, I need help. For my module (see photo) I have to program the exact pulse function on Devo7e (Deviationtx). I have a three position switch and I start in the neutral position (middle). I need: When I switch to one position, I need to transfer a precisely defined pulse (eg 5 seconds) to relay 1. Then I switch to neutral. When I switch to position two (from neutral), I switch relay 2 to the defined pulse length.
Thank you for any help.
18 Oct 2020 03:45 #76896 by Gerry
This topic may have some insight for you.
www.deviationtx.com/forum/7-development/...rs-to-channels#29092
FFS (Forever Fixing Stuff)
18 Oct 2020 16:43 #76898 by Maco33
Thanks Gerry, it's amazing, but I will need many evenings to understand and apply :-(
The important thing is that I already know that it is possible ;-)
Time to create page: 0.201 seconds
