In case of loss of comm : RX1202 and Devo12s
05 May 2014 13:57 #22909 by lcn
Hello
I use a RX1202 with Devo12s ( flashed Deviation )
When i power-up my multicopter, RX1202 is always able to bind, to handshake the transmitter, LED turns permanent Green and i can start the flight.
If, so test purposes or in case of loss of communication RX1202 / Devo12s
then the receiver's LED flashes but it is no longer able to recover the communication with the transmitter, even i switch back on the Devo12s.
Actually if a loss of communication happens the TX and RX can't talk each other anymore, this would result for sure to the model crash.
Is there a setting or a way to force the receiver to bind the transmitter when the comm is back to normal ?
05 May 2014 14:10 - 05 May 2014 14:11 #22912 by vlad_vy
Replied by vlad_vy on topic In case of loss of comm : RX1202 and Devo12s
Set 'Fixed ID'.
Last edit: 05 May 2014 14:11 by vlad_vy.
10 May 2014 12:11 #23108 by lcn
Many thanks, it works perfectly now.
Time to create page: 0.138 seconds
