Beeb sound Devo8s
- van Kerkwijk
05 May 2014 21:07 #22920
by van Kerkwijk
Beeb sound Devo8s was created by van Kerkwijk
I am very intersted in Deviation in my Devo8s. First inpressions are good and I will make a vibrator motor in it. Only the timer beeb is sooo soft. Is it possible in de software from Deviation to make the beeb much louder or another sound?
06 May 2014 03:15 #22928
Replied by vlad_vy on topic Beeb sound Devo8s
Volume can be adjusted in Tx settings, but not very loud.
Sounds can be changed in sound.ini (Tx 'media' directory).
The lowest note is 'a'. The progression is:
a, ax, b, c0, cx0, d0, dx0, e0, f0, fx0, g0, gx0, a0, ax0, b0, c1, ...
b4 is the last note
The 'x' stands for sharp, so a, a-sharp, b, ...
The number after the '=' is the number of milliseconds to play for. 1000 = 1 second. And you can use "xx" for a break, "xx=1000" let the sound be quiet for one second.
b4 is the last note
- van Kerkwijk
06 May 2014 18:14 #22951
by van Kerkwijk
Replied by van Kerkwijk on topic Beeb sound Devo8s
Ok, thanks, I will try it.
Time to create page: 0.111 seconds
- Beeb sound Devo8s
