4G6 in wk2801 mode
- whiteturbo
07 May 2014 17:30 #22976
by whiteturbo
4G6 in wk2801 mode was created by whiteturbo
I decided to rebuild, with improvements, my old Walkera 4G6 ccpm i.e not fbl.
I have a devo 10 running 4.01 firmware i have the swash set to 3servo 120x ele -60,ail-60 and pitch 60. in reverse i have rud and pit reversed.everything moves as it should except when using the elevator the pitch servo(from tail in position the right rear) doesn't move. it moves fine with pitch up and down and aileron left and right, just no response when using elevator.
So got my old WK 2801 pro out and all works as it should so its not the servo let go. I am completely stumped! Although im not a noob i have been away from heli's for 3 years playing with tricopters etc so i am a bit rusty. So any help/advice appreciated.
07 May 2014 18:54 #22978
Replied by FDR on topic 4G6 in wk2801 mode
Could you post your model config file?
- whiteturbo
07 May 2014 19:51 #22980
by whiteturbo
Replied by whiteturbo on topic 4G6 in wk2801 mode
Bear in mind that im just setting the 4G6 up as im waiting on parts, so the ini is only at early stage. i think i have done this right, i copied the ini from the models directory.
- -=Hubi-Dirk=-
08 May 2014 18:43 #23023
by -=Hubi-Dirk=-
Replied by -=Hubi-Dirk=- on topic 4G6 in wk2801 mode
try out this model config.
Best
Dirk
Best
Dirk
- whiteturbo
22 May 2014 15:45 #23503
by whiteturbo
Hi Dirk,
Sorry its been so long getting back to you but i was broadbandless for a while.
Anyway thanks for the ini, it seems to work except i havn't a clue how you did it as im only able to use the standard gui. It will motivate me to learn the advanced gui as i cant stand not knowing how to do it myself.
Thanks again
Ray
Thanks again
Ray
Time to create page: 0.419 seconds
- 4G6 in wk2801 mode
