How to init commands sequence from a switch ?
- lcn
10 May 2014 12:20 #23109
by lcn
How to init commands sequence from a switch ? was created by lcn
Hello
I have a Devo12s and was worndering if i could be possible to start a sequence of multiple commands ( something like a program or scenario ) from a switch.
I have a multirotor and during a flight, especially when filming i would find usefull to have the multirotor moving arround a point very slowly ( 360° turn )
Is it possible to set a sequence of commands ( throttle, rudder, yaw ) that will start an automatic programmed round move when engaging a switch button ?
Thanks for your experience,
10 May 2014 12:36 #23111
Replied by PhracturedBlue on topic How to init commands sequence from a switch ?
no there is no feasibility for that. It sounds pretty dangerous to do as well.
- esklarski
11 May 2014 19:31 #23148
by esklarski
Replied by esklarski on topic How to init commands sequence from a switch ?
This sounds like something that should be handled through the Flight Controller on your multirotor. I bet with some programming know-how MultiWii could do what you're looking for.
- lcn
12 May 2014 21:29 #23163
by lcn
Replied by lcn on topic How to init commands sequence from a switch ?
My flight controller is DJI Nava v2.
Does someone know if a 360° turn and moving arround a point could be performed from a switch action ?
- csarchette72
14 May 2014 01:47 #23216
by csarchette72
Replied by csarchette72 on topic How to init commands sequence from a switch ?
I know APM fc does this in circle mode.
Time to create page: 0.109 seconds
- How to init commands sequence from a switch ?
