3 Modules....1 Antenna?
21 May 2014 07:38 #23441 by Solmer
3 Modules....1 Antenna? was created by Solmer
Hi, I've bought another Devo, a 8S and I wonder if I can put two modules inside connected to the same antenna. My Devo 7e has two antena with three modules (Walkera, A7105 and CC2500) the A7105 antenna goes inside the original tube of the radio and for the CC2500 I've put another connector to attach the antenna.
My idea is soldering the two modules to the original Devo antenna...Could be it possible?.
Thanks in advance.
21 May 2014 07:54 - 21 May 2014 08:07 #23442 by SeByDocKy
Replied by SeByDocKy on topic 3 Modules....1 Antenna?
Solmer wrote: Hi, I've bought another Devo, a 8S and I wonder if I can put two modules inside connected to the same antenna. My Devo 7e has two antena with three modules (Walkera, A7105 and CC2500) the A7105 antenna goes inside the original tube of the radio and for the CC2500 I've put another connector to attach the antenna.
Thanks in advance.
As said in "Ghosbusters" movie ... "Never cross beams". Well ...If you are 1000% that the two others RFchips are off when using one, it may possible. But I am not sure it's the case. So by the way, it's not a good idea.
More, you should "desadapt" the RFline and lost some power transmission in best case. In the worst, you can damage your RF conpounds
Last edit: 21 May 2014 08:07 by SeByDocKy.
21 May 2014 08:04 #23443 by Solmer
Replied by Solmer on topic 3 Modules....1 Antenna?
Hi SeBydocky, you're right ... " Never cross beams" :lol: As I had feared though, that is not a good idea...I'm afraid about burning my new 8s..so I'm gonna put another connector on it....I'm thinking about putting the A7105 module with a new connector (because I use the module to fly my Glider which needs more range) and leaving the CC2500 antenna inside the radio (I use it to fly my micro heli...) What do you think?
Thanks in advance.
Time to create page: 0.121 seconds
