Binding
- Torch
31 May 2014 05:02 - 31 May 2014 05:05 #23776
by Torch
Binding was created by Torch
Just installed Deviation 4 on Devo 7E how do I bind it to my aircraft? I have v120d02 v2 and QR ladybird. Not able to bind either one. I can copy Tom Z's models also but they won't bind.
Starting to panic now can how I go back to my Walkera Devo 7E orginal firmware? I tried using the DfsuE tool and upgrading it back to the latest devo 7e firmware but it boots up to the word Throttle STick and I can't input or doing thing.
Help I can't fly anything!
Last edit: 31 May 2014 05:05 by Torch.
31 May 2014 07:33 #23777
Replied by FDR on topic Binding
T bind auzomatically you need to clear the Fixed ID field on the model setup page.
If you used your models with Fixed ID with the stock fw, you can enter those values, and they will work in deviation too, or if you don't remember them, you will need to clear the fixed ids from the receivers.
The stock fw probably installed with wrong stick mode setting, so try to lower both sticks to dismiss the throttle warning...
- Tom Z
02 Jun 2014 02:31 #23836
by Tom Z
Replied by Tom Z on topic Binding
Torch, I have notes on my model pages if your model(s) don't bind for you what you need to do.
This is similar to what FDR posted for you in post #23777.
Here is my note.
Fixed ID
My model does not use a Fixed ID.
If you used a Fixed ID with the original Walkera firmware you must clear the Fixed ID in the Receiver with the Bind Plug.
If you don't clear the Fixed ID the model will not bind.
If you want to use a Fixed ID you can enter the same Fixed ID you had for the original Walkera firmware.
Example: Your original Walkera firmware Fixed ID was: 123456
Assign the Deviation Fixed ID: 123456
You can also assign any Fixed ID that you want to use. You don't have to use the original Walkera firmware Fixed ID. Clear the Fixed ID in the Receiver
with the Bind Plug then assign any Fixed ID that you want to use.
You will get a "Throttle Stick" warning if your throttle stick is not all the way down when you boot up. Make sure the throttle stick is all the way down on boot up.
You will also get a warning if your FMOD switch is on FMOD 1 when you boot up. Make sure your FMOD switch is on FMOD 0 when you boot up.
These are both warnings Walkera put in the factory firmware. This also applies to all the other model transmitters.
Here is my note.
Fixed ID
Time to create page: 0.067 seconds
- Binding
