Delayed channel function
07 Jun 2014 22:32 #23955 by Jman841
Delayed channel function was created by Jman841
I am going to be running the ikon FBL on my Compass 6hvu and want to have the ability to set the self level bank activate and then after a 1-2 second delay have positive pitch applied so it can have time to level itself out and then punch up like a true bailout feature.
Is this a possibility? How can I go about doing this?
08 Jun 2014 22:56 #23977 by PhracturedBlue
Replied by PhracturedBlue on topic Delayed channel function
The advanced mixer has a delay feature. What it does is to slow down the servo response by the amount of the curve. A value of 100 represents 5 seconds. So if your 1st mixer is a min/max curve, and your delay mxer uses a fixed curve with a value of 100, when you flip a switch, it will take 5 seconds for the servo to smoothly move from -100 to 100.
To create a delayed action, you can then set a second channel using the delayed mixer as an input and use a min/max. You can see an example of something similar here:
www.deviationtx.com/forum/3-feedback-que...position-delay#23558
10 Jun 2014 05:59 #24011 by Jman841
Replied by Jman841 on topic Delayed channel function
Awesome! thank you very much!
Time to create page: 0.318 seconds
