how do i connect TAROT ZYX S2 to DSM2 Sat.
- alphonso
26 Jul 2014 14:20 #24810
by alphonso
how do i connect TAROT ZYX S2 to DSM2 Sat. was created by alphonso
Hi there, I have just bought a Devo 10 and uploaded Deviation. I want to run my Gaui 200 FES with the Tarot ZYX S2 FBL unit. I thought I just needed a DSM2 sat but the sat has a different connector to any on the Tarot ZYX. Reading through some old posts, I think it looks like I need another adapter cable or must bind to a spektrum RX first. i was worried I may have bought the wrong gear and should have gone the AR7200BX route for simplicity.
If someone has some experience with these units and setting them up then I would appreciate some help.
allan
allan
- Arakon
27 Jul 2014 06:37 #24835
by Arakon
Replied by Arakon on topic how do i connect TAROT ZYX S2 to DSM2 Sat.
You also need this, as the sat runs on 3.3V, while the device gives out 5V.
www.ebay.de/itm/Tarot-3-Axis-Flybarless-...&hash=item2c6dfcafb7
However, you'll need to bind the satellite to a normal Spektrum receiver first. If you have an arduino sitting around, you can instead use that to bind it.
github.com/jbudworth/SpektrumSatRx/blob/...atellite_Rx_Bind.ino
That code will allow you to hook up the satellite to the arduino to bind.
- alphonso
27 Jul 2014 09:03 #24844
by alphonso
Replied by alphonso on topic how do i connect TAROT ZYX S2 to DSM2 Sat.
thankyou mate.exactly what I was suspecting. How many channels do I need on the Spektrum RX or does it not matter for that initial bind.
Allan
Allan
- Arakon
27 Jul 2014 18:04 #24855
by Arakon
I had trouble when I bound a sat with 6 channels and later set my TX to 8 channels.. so preferably, it should match the amount of channels you actually want to use.
Time to create page: 0.193 seconds
- how do i connect TAROT ZYX S2 to DSM2 Sat.
