28 and counting....
17 Aug 2014 22:07 #25253 by Blayd
28 and counting.... was created by Blayd
Just alittle info for those who ask....
Yes. I fly a 700 on Deviation 4.0.1 using a Devo 8S, running in 2801Pro protocol on a 2801 Pro Rx.
I also fly three 500's using the Devo protocol.
Today was flights 26, 27, and 28, on the 700. Flawless. Rock solid.
First up, the usual failsafe check. Perfect. Motor shut down as it should.
Still havent set up the servos yet to go to a nuetral setting, right now, I believe they stay at last input.
TH and governor working fine..
Range check was, well, I couldnt get far enough from the heli to induce failsafe...thats a good thing.
Today, I took the 700 MUCH farther then any previous flights, further then I normally would by a long shot, pushing my own abilities to keep orientation correctly. You would have thought I was doing FPV flying it was so far out.
All went well.
Question....
What is The minimum voltage for maximum signal? 4.5v? Right now, I think I have my warning set to 4.75v...
Thanks in advance.
Devo 8S
Trex500ESP
Trex500ESP (Belted tail)
HC500SE
Trex700N2E
19 Aug 2014 07:58 - 19 Aug 2014 08:33 #25283 by Birdman
Replied by Birdman on topic 28 and counting....
I was thinking the rf module operated at 3.3v off a regulator.
Therefore min voltage warning for 8s would be determined by min safe voltage of battery used because it would be well above dropout voltage of reg (edit: unless using 1s).
So battery voltage has no effect on signal output.
But i could be wrong.
Bm
Last edit: 19 Aug 2014 08:33 by Birdman.
19 Aug 2014 08:27 #25284 by Birdman
19 Aug 2014 21:19 #25298 by Blayd
Replied by Blayd on topic 28 and counting....
Thanks Birdman.... I just want to make sure I dont take the 8S down too low. So I was trying to see where everybody is setting the warning for the battery voltage.
Devo 8S
Trex500ESP
HC500SE
Trex700N2E
Time to create page: 1.196 seconds
