Devo 7E and esky 150
09 Sep 2014 16:14 #25571 by sonyv12002
Devo 7E and esky 150 was created by sonyv12002
I cannt bind the esky 150 even if I installed the nRF24L01+PA+LNA chip. Will there be an update for Devo 7E to bind it correctly? I'm a mode 1 flyer, totally cannt fly mode 2 default transmitter:(
30 Sep 2014 19:49 #25890 by SirDomsen
Replied by SirDomsen on topic Devo 7E and esky 150
Tried to switch the stock tx to mode1? Should,be possible!
01 Oct 2014 05:45 #25898 by SeByDocKy
Replied by SeByDocKy on topic Devo 7E and esky 150
Yes there is a small bug for the Devo7E ... Victzh who did the hack seems to involve in different projects now ....
What is strange it's working for a devo10 not for the 7E ....
01 Oct 2014 16:46 #25901 by victzh
Replied by victzh on topic Devo 7E and esky 150
It's hard to debug - I don't have nRF24L01 installed in my Devo 7E yet, and, mainly, I don't have Esky 150!
What specifically does not work?
01 Oct 2014 17:41 #25902 by SeByDocKy
victzh wrote: It's hard to debug - I don't have nRF24L01 installed in my Devo 7E yet, and, mainly, I don't have Esky 150!
Not binding ....
01 Oct 2014 22:34 #25907 by Daryoon
Replied by Daryoon on topic Devo 7E and esky 150
The Esky 150 protocol works for the Devo 10 radio. Binds fine.
But the Devo 7e won't bind when using that same protocol.
02 Oct 2014 04:22 #25909 by sonyv12002
Replied by sonyv12002 on topic Devo 7E and esky 150
I thought this thread is dead :side:
Thanks for all the reply. Yes, it doest not bind the heli. Try Fix ID and None also doesn't work. :(
Disassemble the default TX, if want to mod from mode 2 to mode 1 there will be lot of works. Need to shit whole left stick to right involve soldering and some wiring.
02 Oct 2014 05:34 #25913 by SeByDocKy
Concerning the Devo7E problem, ... I can feel it's a syncrho problem.
I mean maybe by increasing/decreasing some time delay used during the protocol setup....
02 Oct 2014 16:17 #25920 by victzh
sonyv12002 wrote: I thought this thread is dead :side:
Actually, maybe not. Check that you can't just move the spring which keeps the stick in the middle position from the right stick to the left.
02 Oct 2014 16:40 #25922 by victzh
SeByDocKy wrote: Concerning the Devo7E problem, ... I can feel it's a syncrho problem.
Funny, no other protocol has this problem. As I don't have the heli, even the receiver board, I can't check it. I was amazed that our distance debugging worked for the protocol reverse engineering, but this case seems to be harder. You'll need to get traces from Devo 10 and Devo 7E and we'll need to compare them and find the difference.
02 Oct 2014 16:44 #25923 by victzh
Check this thread - it's couple of screws:
www.helifreak.com/showthread.php?t=554545
and it's actually in Devo 7E manual ;-)
02 Oct 2014 17:19 #25924 by SeByDocKy
How to get traces ? In debug mode ?
03 Oct 2014 02:34 - 03 Oct 2014 02:37 #25932 by sonyv12002
Sorry I mean the stock TX from Esky.
I love the 7E, but thinking to upgrade to devo 10. Have a spare is not a bad idea.
Last edit: 03 Oct 2014 02:37 by sonyv12002.
27 Oct 2014 15:29 #26181 by SeByDocKy
I recently received the ESKY F300BL for reviewing and they change the protocol even based on the RFchip. I am sure, they just changed some Id packets, basic stuff like this.
Victzh, I can sniff SPI data in case ?
09 Jun 2016 16:33 #50255 by dado099
Replied by dado099 on topic Devo 7E and esky 150
Hi SeBy, sorry for reopening this thread so late.
Are you still able to capture SPI data from ESKY F300BL and pass them to Victzh so he can also implement this protocol small variation ?
Thank you so much.
Time to create page: 0.387 seconds
