Safe value?
- RobC62
23 Dec 2014 22:30 #27173
by RobC62
Replied by RobC62 on topic Safe value?
I use Mode 2.
I have another Devo 7E that I will be flashing tonight/tomorrow and setting up a single model only in DSM2 or DSMX protocol. From memory, last one I did I changed stick mode before setting up the model, but am not 100% certain of that. Will report back on the error, and pass the .ini file over.
24 Dec 2014 01:34 #27188
Replied by mwm on topic Safe value?
On further investigation (and some thought), the emulator is behaving properly.
It sets the sticks on start up. Changing mode after that changes the interpretation of the sticks without changing their position. So the throttle & elevator moving back and forth when you change their interpretation by changing the mode is correct. If you shut down and restart the emulator, the throttle output channel is always set to min.
24 Dec 2014 02:30 #27189
And now the mode issue is explained. Yup, I was getting CH3 warnings. Because my right stick was centered.
So, if you someone could post a model file that had these problems, it would be a big help!
Time to create page: 0.084 seconds
- Safe value?
