Help in setting up IKON fbl unit to deviation
- stepels
11 Dec 2014 08:50 #26890
by stepels
Help in setting up IKON fbl unit to deviation was created by stepels
This is my first post on this forum, I have a Devo 10 using Deviation. My question is that im trying to set up an IKON fbl unit and i think, or seem to need 7 ch for everything to work, that is ch1 to ch6 the normal ch used and i think i need to use another to switch through the 3 different modes in the fbl unit. Can i use a template in the standard gui or do i have to use advanced gui? i want to use the gear switch for the gyro and the mix switch for the 3 modes in the IKON. Can anyone help??
- MacGyverek
11 Dec 2014 09:36 #26891
by MacGyverek
Replied by MacGyverek on topic Help in setting up IKON fbl unit to deviation
I using MSH Brain on DEVO8S with DSMX Satelite. All configuration you must do in advanced menu.
What RX you are using?? Maybe I help you.
- stepels
12 Dec 2014 09:05 #26913
by stepels
Replied by stepels on topic Help in setting up IKON fbl unit to deviation
Im using DSM2 single sat. I would be gratefull for your help.
- MacGyverek
14 Dec 2014 13:36 #26967
by MacGyverek
I used DSMX sat. Please change to DSM2 and 8 channel.
- stepels
16 Dec 2014 08:42 #27037
by stepels
Thank you very much for all your help, i'll work through all the settings and see how it goes. I must admit that this looks very complicated at the moment. Cheers
- MacGyverek
16 Dec 2014 09:03 - 16 Dec 2014 09:04 #27039
by MacGyverek
I have the same problem when I start with DeviationTX firmware and advanced menu. But now its very simple. You must take a beer and play few hour with it. Very often I am using Emulator for do all settings.
P.S. Sorry for my English.
Last edit: 16 Dec 2014 09:04 by MacGyverek.
- stepels
28 Feb 2015 20:32 #29214
by stepels
Hi all, I've got my IKON and my DEVO 10 to work with the DeViation software (4.0.1). Im using the mix switch to use the 3 modes in the IKON which works very well. The question I have is I want to mix in to one of the modes triggered by say mix 0, to not just activete the mode in the IKON but to also link to pitch so i can input + pitch when i trigger the self level in mix 0. Can anyone suggest how i can do this??? Cheers
- stepels
06 Mar 2015 08:38 #29392
by stepels
Its been awhile but thank you all who have helpped me with setting up my Devo 10 to my IKON, I now have ALL modes with my IKON bar the auto rotation setup. Ill write my setup later, again cheers!!!
Time to create page: 0.492 seconds
- Help in setting up IKON fbl unit to deviation
