Devo 7e, missing multimod, nightly
- norvik
14 Dec 2014 09:01 #26965
by norvik
Devo 7e, missing multimod, nightly was created by norvik
On my Devo 7e I had the range mod working with 4.0.1.
I installed 2x3 switches and tried to get the latest nightly(1.august) to work. Get error: Missing modules: Multimod when I turn on the transmitter.
Tried to edit the hardware.ini file in every possible way. Also left it unedited. Same result.
Used Dfuse and copy/paste the new files. Have checked all the soldering joints several times, looks good.
Everything works fine if I reinstall 4.0.1.
Would really like the 2x3 switches to work.
Have no other mods than the range mod and 2x3 switches on my TX.
Have read every post I could find on this and other sites. Can`t figure out what`s wrong.
Anybody got any idea?
- aMax
14 Dec 2014 15:08 - 14 Dec 2014 15:12 #26969
by aMax
Replied by aMax on topic Devo 7e, missing multimod, nightly
Did you edit the hardware.ini the right way?
If yes, I can provide you with an older nightly (...for testing purpose and without KN)that I was using until september.
Switches and the diode mod are supported. But no multimod.
I am not shure if the multimod is supported on the 7e.
Last edit: 14 Dec 2014 15:12 by aMax.
- norvik
14 Dec 2014 17:57 #26975
by norvik
Replied by norvik on topic Devo 7e, missing multimod, nightly
I think it`s edited the right way. Even if I leave the file unedited I get the error message. The only mods I have is the range and hopefully the switch mod soon, so I don`t need a nightly who support multimod.
Would appreciate testing the earlier version.
As far as I understand the TX should work with the nightly and an unedited hardware.ini? (of course the switches wont work until hardware.ini is edited)
- aMax
14 Dec 2014 19:02 #26976
by aMax
There is a change. Previously the PA was aktiv on the cyrf6936. Now on
the 7e it is off by default. So if no edit(even with range mod) > no pa.....
Testfile added.
Testfile added.
- norvik
15 Dec 2014 16:53 - 15 Dec 2014 16:55 #27007
by norvik
Thanks aMax,
Just tested the files. Unfortunately it did`t work out. I still get the "missing multimod" screen when I turn it on.
Attached is my hardware.ini file. I think it`s edited the right way to get the TX working.
Just can`t figure out what I have done wrong.
Thanks aMax,
Last edit: 15 Dec 2014 16:55 by norvik. Reason: New attachment
- Horst0414
15 Dec 2014 18:29 - 15 Dec 2014 18:30 #27009
by Horst0414
Replied by Horst0414 on topic Devo 7e, missing multimod, nightly
I had also problems with my 7E and 2 3-way switches. Maybe my hardware.ini will work for you
Greetings
Horst
Greetings
Horst
Last edit: 15 Dec 2014 18:30 by Horst0414.
- aMax
15 Dec 2014 18:57 - 15 Dec 2014 19:04 #27011
by aMax
@norvik
You activated a second CYRF which is not installed!!!! (B12)
The switches (3x2) are not activated......
You really need to edit the file the right way....LOL
EDIT:
Take the file of horst and activate the pa .
EDIT:
Last edit: 15 Dec 2014 19:04 by aMax.
- aMax
15 Dec 2014 19:05 - 15 Dec 2014 19:06 #27012
by aMax
Which version of Deviation ?Horst0414 wrote: Hello,
Greetings
Horst
Last edit: 15 Dec 2014 19:06 by aMax.
- norvik
15 Dec 2014 19:09 - 15 Dec 2014 19:11 #27013
by norvik
Thanks,
Have tried to edit the file in every possible way. Still can`t get it to work. Now I have it edited like Horst(I think), but still no luck.
I`m sure you already understand that the computer side of mods is not my strongest side:-)
Last edit: 15 Dec 2014 19:11 by norvik. Reason: spelling
- aMax
15 Dec 2014 19:15 - 15 Dec 2014 19:24 #27014
by aMax
For the range mod>> has_pa-cyrf6936 = 1
Which version of firmware is on the tx now?
What kind of editor are you using for that edit?
Edit:
Are the diodes in the right direction to the switches?
Edit:
Last edit: 15 Dec 2014 19:24 by aMax.
- norvik
15 Dec 2014 19:46 - 15 Dec 2014 20:01 #27019
by norvik
I`m using the "until September" version you provided on the TX and I use Notepad++.
The diodes has the line nearest to the switch. Maybe my diodes are the wrong type? This is the diods I`m using:
Last edit: 15 Dec 2014 20:01 by norvik. Reason: Picture
- aMax
15 Dec 2014 20:12 - 15 Dec 2014 20:19 #27020
by aMax
Standart diodes. I used small fast switching diodes 1N4148.
Wiring looks ok.
Wiring looks ok.
Last edit: 15 Dec 2014 20:19 by aMax.
- norvik
15 Dec 2014 20:17 - 15 Dec 2014 20:18 #27021
by norvik
Ok, I have already ordered 1N4148 diods. Will let you know if it solves my issue or not. Thanks.
Last edit: 15 Dec 2014 20:18 by norvik. Reason: Spelling
- Horst0414
15 Dec 2014 21:17 - 15 Dec 2014 21:34 #27023
by Horst0414
it is version deviation-devo7e-v4.0.1-92e1705
My complete hardware.ini is shown in the attachment. I have the A7105 also installed.
I had also the missing module error. After setting
"has_pa-cyrf6936 = 0" it worked.
aMax wrote:
Which version of Deviation ?Horst0414 wrote: I had also problems with my 7E and 2 3-way switches. Maybe my hardware.ini will work for you
Last edit: 15 Dec 2014 21:34 by Horst0414.
- Hr
28 Feb 2015 19:32 #29211
by Hr
Replied by Hr on topic Devo 7e, switches mod problem
Hi friends
I made the switches mod and installed the deviation-devo7e-v4.0.1-92e1705
And updated the hardwere ini but cant see any additional switches in the transmitter manual any help ??
- Deal57
28 Feb 2015 21:06 #29215
by Deal57
Replied by Deal57 on topic Devo 7e, switches mod problem
If you've followed the previous posts, and the diodes are right and the hardware.ini is right, they'll be there. They show up as SWA and SWB in the transmitter stick input menu.
If they don't show up its the wiring. Oh, maybe check that you're batteries are fresh, too.
- Hr
01 Mar 2015 06:49 - 01 Mar 2015 07:07 #29225
by Hr
Hi
I used 1N4007 diodes is it ok?
There is in the transmitter an old empty (0 bite and no text )dfu file v 3.0 that I cant Dalit from the transmitter
Any idea how to move it ,maybe this the problem??
Last edit: 01 Mar 2015 07:07 by Hr.
- Deal57
01 Mar 2015 14:06 #29229
by Deal57
I can't tell you anything about using the 1N4007 vs the 1N4148, except the 1n4148 is what I see that works every time. What I read about the 4007 leads me to think it could work, but I personally would use the most desirable components to fly my $300 birds.
As far as the file you're seeing, perhaps it makes sense to go through the flash process once more... If your run the DFU upgrade, then in USB mode reformat the drive, then copy over the file system, you'll have a fresh and totally complete installation. Make sure you backup any customized files before you start (if you have any).
And did I mention fresh batteries? If the batteries drain during your work, the flash writes may not work the way you want them to work.
- Hr
01 Mar 2015 18:26 - 01 Mar 2015 18:26 #29241
by Hr
Hi thank you for your answers
Please clarify ,if the switches are wrong wired or not wired at all Will influence that the new switches assignment Will not shown in the switches assignment Manu on the transmitter or just will not be working.
In my case in the switches assignment or mixer Manu there is no new SW
Last edit: 01 Mar 2015 18:26 by Hr.
- Deal57
01 Mar 2015 20:10 #29247
by Deal57
If the switches are wired wrong you probably won't see them in the switch assignment menus or on the Stick Input screen under Transmitter Menu ->Channel Monitor; if they are wired right but the diodes are wrong, IIRC they won't show up AND it seems to affect the trims.
Can you take a photo like the first one in post 27019 above? Maybe at least we can confirm the wiring.
Time to create page: 0.485 seconds
- Devo 7e, missing multimod, nightly
