New to Deviation and have a couple questions
- SciPunk
16 Dec 2014 09:45 - 16 Dec 2014 09:46 #27041
by SciPunk
New to Deviation and have a couple questions was created by SciPunk
Hey all,
Just got my Devo 7E today and have the current stable build of Deviation installed and have both my micro heli's in the TX. Both blade heli's using DSM2 as the protcol. MCX I added myself and for the MCX2 i used Daryoons ini.
Here are my questions:
I have to bind it every time i switch models, even though i load them. Is this normal?
How do i save the models in the tx, when i swap to one the other says unsaved. Does it have to be done via USB?
I have read a lot while i waited for this to show up. I have mods planned (especially the battery connector, range, switches and led.
Last edit: 16 Dec 2014 09:46 by SciPunk.
16 Dec 2014 15:43 #27045
Use the USB to back up your models to a pc.
Replied by hexfet on topic New to Deviation and have a couple questions
Try setting the fixed id in the model config.SciPunk wrote: I have to bind it every time i switch models, even though i load them. Is this normal?
Changes are saved automatically when you load a different model or turn off the tx. There's more info in this post .SciPunk wrote: How do i save the models in the tx, when i swap to one the other says unsaved. Does it have to be done via USB?
- Kdean
16 Dec 2014 15:55 #27046
by Kdean
Replied by Kdean on topic New to Deviation and have a couple questions
Welcome Psychlic, your in the right place.
- SciPunk
16 Dec 2014 19:08 #27048
by SciPunk
Replied by SciPunk on topic New to Deviation and have a couple questions
Thanks guys, i really do love the radio and these were a couple things that were eluding me.
I will try the ID number thing today and report back.
Later today i am gonna grab either a pair of dean plugs or jst's and fix this horrid battery connector...lol
- SciPunk
17 Dec 2014 08:18 #27062
by SciPunk
Update:
It seems the ID numbers worked, the MCX bound as soon as it calibrated it's gyro
Thanks again!
Thanks again!
Time to create page: 0.108 seconds
- New to Deviation and have a couple questions
