Devo 12s multiple receivers
- feldmanj
30 Dec 2014 19:36 - 30 Dec 2014 19:36 #27352
by feldmanj
Devo 12s multiple receivers was created by feldmanj
I have a Devo 12s with the RX1201 RX. Since you can have multiple planes defined in the TX, I am thinking about buying another RX1201 for another plane. My question is can you have multiple RX bond to the same TX? So I would have one RX in plane#1 and another RX in plane#2. By selecting the appropriate plane in the TX would the second RX still be bond. Or does one need to rebind the RX with each use?
How does this play with the fixed ID?
Jerry
Jerry
Last edit: 30 Dec 2014 19:36 by feldmanj.
- mikemacwillie
30 Dec 2014 20:54 #27357
by mikemacwillie
Replied by mikemacwillie on topic Devo 12s multiple receivers
Yeah, you can have a separate receiver for every model (Most people do). If you set a different fixed ID for each, then they will only connect when the correct model is selected, preventing you from trying to fly with the wrong settings for your model.
- feldmanj
30 Dec 2014 21:08 #27359
by feldmanj
Replied by feldmanj on topic Devo 12s multiple receivers
Devo 12s is just way 2 cool! Thanks for the info.
Time to create page: 0.195 seconds
- Devo 12s multiple receivers
