DEVO 10 AUX4 Setting Help~~
17 Jan 2015 03:15 #27753 by brittledia
DEVO 10 AUX4 Setting Help~~ was created by brittledia
Hi~
I have Devo 10 with deviation v4.0.1
I bound with mini CP. But I don't know setting channel 7 (Gyro)
My ini file is this,
[channel7]
template=expo_dr
[mixer]
src=MIX0
dest=Ch7
scalar=50
curvetype=fixed
[mixer]
src=MIX0
dest=Ch7
switch=MIX1
scalar=40
curvetype=fixed
[mixer]
src=MIX0
dest=Ch7
switch=MIX2
scalar=0
curvetype=fixed
I want to mix AUX4 to channel 7.
But, when I check "Chennel monitor", channel 7 did not change.(actually It changed by MIX switch)
How can it change by AUX4 knob?
17 Jan 2015 04:19 #27755 by mwm
Replied by mwm on topic DEVO 10 AUX4 Setting Help~~
I use MIX with AUX5 for gimbal control - MIX0 & MIX1 are fixed forward/down looks, and MIX2 uses AUX5 to control the angle of the gimbal. You want a mixer like this:
[mixer]
src=AUX5
dest=Ch7
switch=MIX2
On the Tx in Model menu -> Mixer -> CH7, if you just want AUX4 to control it, change the mix type to Simple, set the SRC to AUX4, and the curve to 1-1. Adjust scale and range to taste. If you want to have AUX4 enabled by one of the MIX switches, go to the mix that uses that switch setting (page 1 will be MIX0), and then set the SRC and curve type as above.
05 Feb 2015 09:59 #28408 by brittledia
Replied by brittledia on topic DEVO 10 AUX4 Setting Help~~
Thank you~ mvm
It work.
Time to create page: 0.081 seconds
