Just received DEVO 12S....
25 Jan 2015 08:10 #28000 by Block137
Just received DEVO 12S.... was created by Block137
Problems first:
For unknown reason, real time clock resets every power cycle.
Few glitches while playing with mainpage config toggle icons which need reboot to fix.
Touch screen trolled me after Deviation upgrade without calibration :pinch:
That's all
So far so good
I can just copy models folder from DEVO 10.
**DANGER! DEVO 12(S) has its own HOLD switch not RUDD D/R. Make sure to assign new hold switch after copying models from different Tx.
Screen is readable in sunlight! (Tested in Bangkok-sun at 3PM)
Completely agree, will never go back to buttons interface
Switches and knobs feel much better than DEVO10 (sticks feel similar however)
Better than DEVO F12E (not considering FPV capability) IMO
25 Jan 2015 08:34 #28001 by vlad_vy
Replied by vlad_vy on topic Just received DEVO 12S....
Check real time clock battery inside Tx, probably it need to be replaced.
25 Jan 2015 10:06 #28007 by Block137
Replied by Block137 on topic Just received DEVO 12S....
Almost opened the whole Tx to find that battery
Turned out to be just under the main battery (Yes, Battery under Battery)
Found a CR1220 Li cell with 0.18V remaining :ohmy:
Time to create page: 0.036 seconds
