Why does DEVO 7E beep at me?
19 Feb 2015 03:36 #28872 by ohaya
Why does DEVO 7E beep at me? was created by ohaya
I am using DEVO 7E with 4.0.1 and the Nano QX model, and I notice that after awhile, the 7E starts beeping at me intermittently.
Is this something that is set in the model, and why would it be doing that?
Thanks,
Jim
19 Feb 2015 03:59 #28873 by mikemacwillie
Replied by mikemacwillie on topic Why does DEVO 7E beep at me?
Could be any one of the configurable alarms. Count down timer, tx battery voltage, etc.
19 Feb 2015 04:09 #28874 by ohaya
Replied by ohaya on topic Why does DEVO 7E beep at me?
This is the model that I've been using. Would info about what might be causing the beeps be in there:
name=Nano QX
mixermode=Advanced
[radio]
protocol=DSMX
num_channels=6
tx_power=10mW
[protocol_opts]
Telemetry=On
[channel1]
template=complex
[mixer]
src=THR
dest=Ch1
usetrim=0
curvetype=5point
points=-100,-60,0,60,100
[channel2]
template=expo_dr
[mixer]
src=AIL
dest=Ch2
scalar=80
curvetype=expo
points=-20,-20
[mixer]
src=AIL
dest=Ch2
switch=FMODE1
curvetype=expo
points=0,0
[channel3]
template=expo_dr
[mixer]
src=ELE
dest=Ch3
scalar=80
curvetype=expo
points=-20,-20
[mixer]
src=ELE
dest=Ch3
switch=FMODE1
curvetype=expo
points=0,0
[channel4]
template=expo_dr
[mixer]
src=RUD
dest=Ch4
curvetype=expo
points=-15,-15
[mixer]
src=RUD
dest=Ch4
switch=FMODE1
curvetype=expo
points=-15,-15
[channel6]
speed=47
template=complex
[mixer]
src=Virt1
dest=Ch6
curvetype=min/max
[mixer]
src=Virt2
dest=Ch6
usetrim=0
curvetype=min/max
[virtchan1]
template=simple
[mixer]
src=HOLD1
dest=Virt1
curvetype=min/max
[virtchan2]
template=simple
[mixer]
src=HOLD1
dest=Virt2
curvetype=min/max
[trim1]
src=LEFT_V
pos=TRIMLV+
neg=TRIMLV-
[trim2]
src=RIGHT_V
pos=TRIMRV+
neg=TRIMRV-
[trim3]
src=LEFT_H
pos=TRIMLH+
neg=TRIMLH-
[trim4]
src=RIGHT_H
pos=TRIMRH+
neg=TRIMRH-
[swash]
type=140
[timer1]
type=countdown
src=THR
time=330
[timer2]
src=THR
[timer4]
src=THR
[safety]
Ch1=min
[gui-qvga]
trim=4in
barsize=half
box1=Ch1
box2=Timer1
box3=Timer2
bar1=Ch1
bar2=Ch2
bar3=Ch3
bar4=Ch4
toggle1=HOLD
tglico1=0,1,0
toggle2=HOLD
tglico2=0,0,0
toggle3=HOLD
tglico3=0,2,0
toggle4=HOLD
tglico4=0,4,0
quickpage1=Model setup
quickpage2=Mixer
quickpage3=None
quickpage4=None
19 Feb 2015 05:23 #28876 by Arakon
Replied by Arakon on topic Why does DEVO 7E beep at me?
[timer1]
type=countdown
src=THR
time=330
This, I guess. It means after 5:30, it warns you.
19 Feb 2015 06:10 #28877 by ohaya
I guess that I was wondering what the PURPOSE of that timer (and beeping) would be? Is it to avoid using the battery for too long and running it down too far?
19 Feb 2015 06:58 #28878 by Cereal_Killer
Replied by Cereal_Killer on topic Why does DEVO 7E beep at me?
It's mostly for a battery timer, there can also be a stopwatch that you also control via throttle input to count up if you want. That can help you figure what to set the alarm to.
There are also settings to control how long between each set of beeps. Incase you want to make it more annoying.
19 Feb 2015 13:39 #28885 by ohaya
Cereal_Killer wrote: It's mostly for a battery timer, there can also be a stopwatch that you also control via throttle input to count up if you want. That can help you figure what to set the alarm to.
Off-topic, but I've been wondering: Are you the same C_K from BLF?
Later,
Jim
19 Feb 2015 13:47 #28886 by Cereal_Killer
ohaya wrote: Hi,
Later,
Jim
Yep, the one and only!
19 Feb 2015 14:01 #28889 by ohaya
ohaya wrote: Hi,
Later,
Jim
That's great to see you here :)! I wonder if there's anyone else from over there here? I've only gotten interested in quads recently, but now that I have, it seems like there's a lot of overlap in interests :)...
Later,
Jim
Time to create page: 1.075 seconds
