2702v-d problems
- trhodes
07 Mar 2015 01:35 #29419
by trhodes
2702v-d problems was created by trhodes
Hi All,
Well I have the Atom 500 with the ar7200bx dialed in. Flies great. But, I can't seem to get the CopterX Black Angel 450 with the 2702v-d to fly well. In fact it is all over the place. Pulls to the right bad. I am wondering if it is the swash mix. I have swash set at 120 with Ele at 40%, Ail at 40%, and the Pit at 50%. This is what I had before loading the deviation firmware. Anyone have any thoughts? The V400 from walkera seems to be all over the place as well.
- linux-user
07 Mar 2015 07:25 #29421
by linux-user
Isn't the 2702v-d a flybarless system that does the CCPM mixing on its own?
I think - as with all flybarless I am aware of - you should not do any mixing of ELE AIL PIT in the TX.
Replied by linux-user on topic 2702v-d problems
trhodes wrote: I am wondering if it is the swash mix. I have swash set at 120 with Ele at 40%, Ail at 40%, and the Pit at 50%.
- Zaphod
07 Mar 2015 10:56 #29428
by Zaphod
Replied by Zaphod on topic 2702v-d problems
The Rx2702 does its mixing in the tx rather than the Rx. So it sounds like your swash settings are fine.
Check out this video and see if it helps with your setup -http://youtu.be/BUnak6YDdGc
- trhodes
07 Mar 2015 13:53 #29430
by trhodes
Replied by trhodes on topic 2702v-d problems
Thanks Zaphod. But I set up the 2702 in the Devo 10 with devention and had no problems. I believe I am using the same settings with deviation. Something just isn't right. I may just bite the bullet and get a beastx for the black angel.
- Zaphod
07 Mar 2015 15:41 #29432
by Zaphod
Must confess I ripped my 2702 off and replaced it with a 2703D instead. Helis flies beautifully now. I found the video on YouTube after I did the replacement so my 2702 is just sitting in my parts bin.
Good luck with whatever you chose
Time to create page: 0.516 seconds
- 2702v-d problems
