Devo 10 + Deviation 4.01 + Heli-x = 50% throttle
- Zaphod
12 Mar 2015 11:16 #29591
by Zaphod
Devo 10 + Deviation 4.01 + Heli-x = 50% throttle was created by Zaphod
I've setup Heli-x on my laptop and setup a model on the Devo 10 using USBHID. Aileron, elevator and rudder are all detected in Heli-x but throttle / collective only registers from centre stick down. Nothing registers from centre stick up.
I've run the calibration in Heli-x but still get the same result.
Any suggestions?
Title
Any suggestions?
Title
- linux-user
12 Mar 2015 13:35 #29593
by linux-user
Replied by linux-user on topic Devo 10 + Deviation 4.01 + Heli-x = 50% throttle
You are running MS-Windows?
Then maybe you need to calibrate something like "gamepad device" in device-manager before doing any calibration in HELI-X
- Zaphod
13 Mar 2015 00:47 #29619
by Zaphod
Replied by Zaphod on topic Devo 10 + Deviation 4.01 + Heli-x = 50% throttle
Thanks for that. Found the calibration for the game controller but it registered exactly the same.
The model file in the tx was a direct copy of the Phoenix INI here. I've gone in and adjusted the throttle curves and now the collective registers correctly. Just need to adjust the rudder now as a slight move left registers as 100 instead of a gradual increase. Moving right does nothing at all.
- linux-user
13 Mar 2015 07:43 #29627
by linux-user
You may try these.
"heli-x-minimal" has only associated Ch1-ch4.
"heli-x" has additional:
FMOD1 -> ch5
FMOD2 -> ch6
RUD DR1 -> ch7 which I use for TH (=Autorotation in HELI-X)
Maybe this is not ideal, but it's working for me.
Throttle and pitch curves are configured inside HELI-X.
FMOD1 -> ch5
FMOD2 -> ch6
- Zaphod
13 Mar 2015 17:47 #29655
by Zaphod
Thanks mate.I'll give them a try over the weekend and let you know how o go.
Cheers
Cheers
- Zaphod
16 Mar 2015 11:54 #29757
by Zaphod
OK gave the model files a go. Same result on the rudder - left rudder is 100% with the stick at 1%. Right rudder is 0 no matter its position.
No idea what's going on. The tx works fine on Phoenix and my helis. Just not on Heli-x.
- linux-user
16 Mar 2015 17:36 #29765
by linux-user
- Zaphod
16 Mar 2015 23:27 #29771
by Zaphod
Awwwww dammit. Did the Windows calibration of the Deviation Gamepad and it failed repeatedly on the rudder. Played a hunch and changed the USB cable and FMD it worked!!
Thanks so much for your help in getting this up and running! You're worth my weight in gold
Time to create page: 0.231 seconds
- Devo 10 + Deviation 4.01 + Heli-x = 50% throttle
