v272 ini devo 7e
- pmc
19 Mar 2015 14:28 #29880
by pmc
v272 ini devo 7e was created by pmc
hi here is my ini for v272 and devo 7e .i also modified the quad to accept nano tech 160 mah lipo which gives you 6 mins fly time.You need to remove charge socket and battery connector and make a hole in the rear of the cover.
name=V2X2
mixermode=Advanced
[radio]
protocol=V202
num_channels=6
fixed_id=111111
tx_power=150mW
[protocol_opts]
Re-bind=No
[channel1]
reverse=1
template=expo_dr
[mixer]
src=AIL
dest=Ch1
scalar=60
curvetype=expo
points=25,25
[mixer]
src=AIL
dest=Ch1
switch=FMODE1
curvetype=expo
points=15,15
[mixer]
src=AIL
dest=Ch1
scalar=80
curvetype=expo
points=25,25
[mixer]
src=AIL
dest=Ch1
switch=FMODE1
curvetype=expo
points=15,15
[mixer]
src=AIL
dest=Ch1
scalar=60
curvetype=expo
points=-10,-10
[mixer]
src=AIL
dest=Ch1
switch=FMODE0
scalar=60
curvetype=expo
points=-10,-10
[mixer]
src=AIL
dest=Ch1
switch=FMODE1
curvetype=expo
points=-10,-10
[mixer]
src=AIL
dest=Ch1
scalar=80
curvetype=expo
points=25,25
[mixer]
src=AIL
dest=Ch1
switch=FMODE1
curvetype=expo
points=15,15
[mixer]
src=AIL
dest=Ch1
scalar=60
curvetype=expo
points=-10,-10
[mixer]
src=AIL
dest=Ch1
switch=FMODE0
scalar=60
curvetype=expo
points=-10,-10
[mixer]
src=AIL
dest=Ch1
switch=FMODE1
curvetype=expo
points=-10,-10
[mixer]
src=AIL
dest=Ch1
scalar=80
curvetype=expo
points=25,25
[mixer]
src=AIL
dest=Ch1
switch=FMODE1
curvetype=expo
points=15,15
[mixer]
src=AIL
dest=Ch1
scalar=60
curvetype=expo
points=-10,-10
[mixer]
src=AIL
dest=Ch1
switch=FMODE0
scalar=60
curvetype=expo
points=-10,-10
[mixer]
src=AIL
dest=Ch1
switch=FMODE1
curvetype=expo
points=-10,-10
[channel2]
template=complex
[mixer]
src=ELE
dest=Ch2
scalar=60
curvetype=expo
points=25,25
[mixer]
src=ELE
dest=Ch2
switch=FMODE1
curvetype=expo
points=15,15
[mixer]
src=ELE
dest=Ch2
scalar=80
curvetype=expo
points=25,25
[mixer]
src=ELE
dest=Ch2
switch=FMODE1
curvetype=expo
points=15,15
[mixer]
src=ELE
dest=Ch2
scalar=60
curvetype=expo
points=-10,-10
[mixer]
src=ELE
dest=Ch2
switch=FMODE0
scalar=60
curvetype=expo
points=-10,-10
[mixer]
src=ELE
dest=Ch2
switch=FMODE1
curvetype=expo
points=-10,-10
[mixer]
src=ELE
dest=Ch2
scalar=80
curvetype=expo
points=25,25
[mixer]
src=ELE
dest=Ch2
switch=FMODE1
curvetype=expo
points=15,15
[mixer]
src=ELE
dest=Ch2
scalar=60
curvetype=expo
points=-10,-10
[mixer]
src=ELE
dest=Ch2
switch=FMODE0
scalar=60
curvetype=expo
points=-10,-10
[mixer]
src=ELE
dest=Ch2
switch=FMODE1
curvetype=expo
points=-10,-10
[mixer]
src=ELE
dest=Ch2
scalar=80
curvetype=expo
points=25,25
[mixer]
src=ELE
dest=Ch2
switch=FMODE1
curvetype=expo
points=15,15
[mixer]
src=ELE
dest=Ch2
scalar=60
curvetype=expo
points=-10,-10
[mixer]
src=ELE
dest=Ch2
switch=FMODE0
scalar=60
curvetype=expo
points=-10,-10
[mixer]
src=ELE
dest=Ch2
switch=FMODE1
curvetype=expo
points=-10,-10
[channel3]
template=complex
[mixer]
src=THR
dest=Ch3
[mixer]
src=THR
dest=Ch3
[mixer]
src=THR
dest=Ch3
[mixer]
src=THR
dest=Ch3
[mixer]
src=THR
dest=Ch3
[mixer]
src=THR
dest=Ch3
[mixer]
src=THR
dest=Ch3
[channel4]
reverse=1
template=complex
[mixer]
src=RUD
dest=Ch4
curvetype=expo
points=-15,-15
[mixer]
src=RUD
dest=Ch4
scalar=125
curvetype=expo
points=-15,-15
[mixer]
src=RUD
dest=Ch4
[mixer]
src=RUD
dest=Ch4
scalar=125
curvetype=expo
points=-15,-15
[mixer]
src=RUD
dest=Ch4
[mixer]
src=RUD
dest=Ch4
scalar=125
curvetype=expo
points=-15,-15
[mixer]
src=RUD
dest=Ch4
[mixer]
src=RUD
dest=Ch4
[mixer]
src=RUD
dest=Ch4
[mixer]
src=RUD
dest=Ch4
[channel5]
template=simple
[mixer]
src=HOLD1
dest=Ch5
curvetype=expo
points=0,0
[mixer]
src=HOLD1
dest=Ch5
curvetype=expo
points=0,0
[mixer]
src=HOLD1
dest=Ch5
curvetype=expo
points=0,0
[mixer]
src=HOLD1
dest=Ch5
curvetype=expo
points=0,0
[mixer]
src=HOLD1
dest=Ch5
curvetype=expo
points=0,0
[mixer]
src=HOLD1
dest=Ch5
curvetype=expo
points=0,0
[channel6]
template=simple
[mixer]
src=Virt3
dest=Ch6
curvetype=expo
points=0,0
[mixer]
src=FMODE1
dest=Ch6
curvetype=expo
points=0,0
[mixer]
src=HOLD0
dest=Ch6
curvetype=expo
points=0,0
[mixer]
src=FMODE1
dest=Ch6
curvetype=expo
points=0,0
[mixer]
src=HOLD0
dest=Ch6
curvetype=expo
points=0,0
[mixer]
src=FMODE1
dest=Ch6
curvetype=expo
points=0,0
[mixer]
src=HOLD0
dest=Ch6
curvetype=expo
points=0,0
[mixer]
src=HOLD0
dest=Ch6
curvetype=expo
points=0,0
[mixer]
src=HOLD0
dest=Ch6
curvetype=expo
points=0,0
[mixer]
src=HOLD0
dest=Ch6
curvetype=expo
points=0,0
[channel7]
template=simple
[mixer]
src=Virt1
dest=Ch7
curvetype=zero/max
points=0
[mixer]
src=HOLD0
dest=Ch7
curvetype=zero/max
points=0
[mixer]
src=HOLD0
dest=Ch7
curvetype=zero/max
points=0
[mixer]
src=HOLD0
dest=Ch7
curvetype=zero/max
points=0
[channel8]
template=simple
[mixer]
src=Virt2
dest=Ch8
curvetype=zero/max
points=0
[mixer]
src=HOLD1
dest=Ch8
curvetype=zero/max
points=0
[mixer]
src=HOLD1
dest=Ch8
curvetype=zero/max
points=0
[mixer]
src=HOLD1
dest=Ch8
curvetype=zero/max
points=0
[virtchan1]
template=complex
[mixer]
src=AIL
dest=Virt1
scalar=0
curvetype=fixed
[trim1]
src=LEFT_V
pos=TRIMLV+
neg=TRIMLV-
[trim2]
src=RIGHT_V
pos=TRIMRV+
neg=TRIMRV-
[trim3]
src=LEFT_H
pos=TRIMLH+
neg=TRIMLH-
[trim4]
src=RIGHT_H
pos=TRIMRH+
neg=TRIMRH-
[trim5]
src=Virt2
pos=TRIMLV-
step=193
value=-100,0,0
[timer1]
type=countdown
src=Ch3
resetsrc=HOLD1
time=180
[timer2]
src=Ch3
[safety]
Auto=min
[gui-128x64]
V-trim=59,10,0
H-trim=5,59,0
V-trim=65,10,2
H-trim=74,59,4
Small-box=2,22,Ch3
Small-box=2,31,Timer1
Small-box=2,39,Timer2
Model=75,20
Battery=102,1
Toggle=4,10,0,3,0,None
Toggle=13,10,0,5,0,None
Toggle=22,10,0,4,0,None
Toggle=31,10,0,0,0,None
Toggle=40,10,0,0,0,None
TxPower=102,7
V-trim=59,10,1
H-trim=5,59,3
V-trim=65,10,2
H-trim=74,59,4
Small-box=2,22,Ch3
Model=75,20
Battery=102,1
Toggle=4,10,0,3,0,FMODE
Toggle=13,10,0,5,0,HOLD
quickpage1=Telemetry monitor
quickpage2=None
quickpage3=None
quickpage4=None template=simple
[mixer]
src=RUD
dest=Ch4
[channel5]
template=simple
[mixer]
src=HOLD1
dest=Ch5
curvetype=expo
points=0,0
[channel6]
template=simple
[mixer]
src=HOLD0
dest=Ch6
curvetype=expo
points=0,0
[trim1]
src=LEFT_V
pos=TRIMLV+
neg=TRIMLV-
[trim2]
src=RIGHT_V
pos=TRIMRV+
neg=TRIMRV-
[trim3]
src=LEFT_H
pos=TRIMLH+
neg=TRIMLH-
[trim4]
src=RIGHT_H
pos=TRIMRH+
neg=TRIMRH-
[timer1]
type=countdown
src=Ch3
time=180
[timer2]
type=stopwatch
src=Ch3
[safety]
Auto=min
[gui-128x64]
V-trim=59,10,1
H-trim=5,59,3
V-trim=65,10,2
H-trim=74,59,4
Small-box=2,22,Ch3
Model=75,20
Battery=102,1
TxPower=102,7
name=V2X2
mixermode=Advanced
[radio]
protocol=V202
num_channels=6
fixed_id=111111
tx_power=150mW
[protocol_opts]
Re-bind=No
[channel1]
reverse=1
template=expo_dr
[mixer]
src=AIL
dest=Ch1
scalar=60
curvetype=expo
points=25,25
[mixer]
src=AIL
dest=Ch1
switch=FMODE1
curvetype=expo
points=15,15
[mixer]
src=AIL
dest=Ch1
scalar=80
curvetype=expo
points=25,25
[mixer]
src=AIL
dest=Ch1
switch=FMODE1
curvetype=expo
points=15,15
[mixer]
src=AIL
dest=Ch1
scalar=60
curvetype=expo
points=-10,-10
[mixer]
src=AIL
dest=Ch1
switch=FMODE0
scalar=60
curvetype=expo
points=-10,-10
[mixer]
src=AIL
dest=Ch1
switch=FMODE1
curvetype=expo
points=-10,-10
[mixer]
src=AIL
dest=Ch1
scalar=80
curvetype=expo
points=25,25
[mixer]
src=AIL
dest=Ch1
switch=FMODE1
curvetype=expo
points=15,15
[mixer]
src=AIL
dest=Ch1
scalar=60
curvetype=expo
points=-10,-10
[mixer]
src=AIL
dest=Ch1
switch=FMODE0
scalar=60
curvetype=expo
points=-10,-10
[mixer]
src=AIL
dest=Ch1
switch=FMODE1
curvetype=expo
points=-10,-10
[mixer]
src=AIL
dest=Ch1
scalar=80
curvetype=expo
points=25,25
[mixer]
src=AIL
dest=Ch1
switch=FMODE1
curvetype=expo
points=15,15
[mixer]
src=AIL
dest=Ch1
scalar=60
curvetype=expo
points=-10,-10
[mixer]
src=AIL
dest=Ch1
switch=FMODE0
scalar=60
curvetype=expo
points=-10,-10
[mixer]
src=AIL
dest=Ch1
switch=FMODE1
curvetype=expo
points=-10,-10
[channel2]
template=complex
[mixer]
src=ELE
dest=Ch2
scalar=60
curvetype=expo
points=25,25
[mixer]
src=ELE
dest=Ch2
switch=FMODE1
curvetype=expo
points=15,15
[mixer]
src=ELE
dest=Ch2
scalar=80
curvetype=expo
points=25,25
[mixer]
src=ELE
dest=Ch2
switch=FMODE1
curvetype=expo
points=15,15
[mixer]
src=ELE
dest=Ch2
scalar=60
curvetype=expo
points=-10,-10
[mixer]
src=ELE
dest=Ch2
switch=FMODE0
scalar=60
curvetype=expo
points=-10,-10
[mixer]
src=ELE
dest=Ch2
switch=FMODE1
curvetype=expo
points=-10,-10
[mixer]
src=ELE
dest=Ch2
scalar=80
curvetype=expo
points=25,25
[mixer]
src=ELE
dest=Ch2
switch=FMODE1
curvetype=expo
points=15,15
[mixer]
src=ELE
dest=Ch2
scalar=60
curvetype=expo
points=-10,-10
[mixer]
src=ELE
dest=Ch2
switch=FMODE0
scalar=60
curvetype=expo
points=-10,-10
[mixer]
src=ELE
dest=Ch2
switch=FMODE1
curvetype=expo
points=-10,-10
[mixer]
src=ELE
dest=Ch2
scalar=80
curvetype=expo
points=25,25
[mixer]
src=ELE
dest=Ch2
switch=FMODE1
curvetype=expo
points=15,15
[mixer]
src=ELE
dest=Ch2
scalar=60
curvetype=expo
points=-10,-10
[mixer]
src=ELE
dest=Ch2
switch=FMODE0
scalar=60
curvetype=expo
points=-10,-10
[mixer]
src=ELE
dest=Ch2
switch=FMODE1
curvetype=expo
points=-10,-10
[channel3]
template=complex
[mixer]
src=THR
dest=Ch3
[mixer]
src=THR
dest=Ch3
[mixer]
src=THR
dest=Ch3
[mixer]
src=THR
dest=Ch3
[mixer]
src=THR
dest=Ch3
[mixer]
src=THR
dest=Ch3
[mixer]
src=THR
dest=Ch3
[channel4]
reverse=1
template=complex
[mixer]
src=RUD
dest=Ch4
curvetype=expo
points=-15,-15
[mixer]
src=RUD
dest=Ch4
scalar=125
curvetype=expo
points=-15,-15
[mixer]
src=RUD
dest=Ch4
[mixer]
src=RUD
dest=Ch4
scalar=125
curvetype=expo
points=-15,-15
[mixer]
src=RUD
dest=Ch4
[mixer]
src=RUD
dest=Ch4
scalar=125
curvetype=expo
points=-15,-15
[mixer]
src=RUD
dest=Ch4
[mixer]
src=RUD
dest=Ch4
[mixer]
src=RUD
dest=Ch4
[mixer]
src=RUD
dest=Ch4
[channel5]
template=simple
[mixer]
src=HOLD1
dest=Ch5
curvetype=expo
points=0,0
[mixer]
src=HOLD1
dest=Ch5
curvetype=expo
points=0,0
[mixer]
src=HOLD1
dest=Ch5
curvetype=expo
points=0,0
[mixer]
src=HOLD1
dest=Ch5
curvetype=expo
points=0,0
[mixer]
src=HOLD1
dest=Ch5
curvetype=expo
points=0,0
[mixer]
src=HOLD1
dest=Ch5
curvetype=expo
points=0,0
[channel6]
template=simple
[mixer]
src=Virt3
dest=Ch6
curvetype=expo
points=0,0
[mixer]
src=FMODE1
dest=Ch6
curvetype=expo
points=0,0
[mixer]
src=HOLD0
dest=Ch6
curvetype=expo
points=0,0
[mixer]
src=FMODE1
dest=Ch6
curvetype=expo
points=0,0
[mixer]
src=HOLD0
dest=Ch6
curvetype=expo
points=0,0
[mixer]
src=FMODE1
dest=Ch6
curvetype=expo
points=0,0
[mixer]
src=HOLD0
dest=Ch6
curvetype=expo
points=0,0
[mixer]
src=HOLD0
dest=Ch6
curvetype=expo
points=0,0
[mixer]
src=HOLD0
dest=Ch6
curvetype=expo
points=0,0
[mixer]
src=HOLD0
dest=Ch6
curvetype=expo
points=0,0
[channel7]
template=simple
[mixer]
src=Virt1
dest=Ch7
curvetype=zero/max
points=0
[mixer]
src=HOLD0
dest=Ch7
curvetype=zero/max
points=0
[mixer]
src=HOLD0
dest=Ch7
curvetype=zero/max
points=0
[mixer]
src=HOLD0
dest=Ch7
curvetype=zero/max
points=0
[channel8]
template=simple
[mixer]
src=Virt2
dest=Ch8
curvetype=zero/max
points=0
[mixer]
src=HOLD1
dest=Ch8
curvetype=zero/max
points=0
[mixer]
src=HOLD1
dest=Ch8
curvetype=zero/max
points=0
[mixer]
src=HOLD1
dest=Ch8
curvetype=zero/max
points=0
[virtchan1]
template=complex
[mixer]
src=AIL
dest=Virt1
scalar=0
curvetype=fixed
[trim1]
src=LEFT_V
pos=TRIMLV+
neg=TRIMLV-
[trim2]
src=RIGHT_V
pos=TRIMRV+
neg=TRIMRV-
[trim3]
src=LEFT_H
pos=TRIMLH+
neg=TRIMLH-
[trim4]
src=RIGHT_H
pos=TRIMRH+
neg=TRIMRH-
[trim5]
src=Virt2
pos=TRIMLV-
step=193
value=-100,0,0
[timer1]
type=countdown
src=Ch3
resetsrc=HOLD1
time=180
[timer2]
src=Ch3
[safety]
Auto=min
[gui-128x64]
V-trim=59,10,0
H-trim=5,59,0
V-trim=65,10,2
H-trim=74,59,4
Small-box=2,22,Ch3
Model=75,20
Battery=102,1
TxPower=102,7
V-trim=59,10,1
H-trim=5,59,3
V-trim=65,10,2
H-trim=74,59,4
Small-box=2,22,Ch3
Model=75,20
Battery=102,1
quickpage2=None
quickpage3=None
[mixer]
src=RUD
dest=Ch4
[channel5]
template=simple
[mixer]
src=HOLD1
dest=Ch5
curvetype=expo
points=0,0
[channel6]
template=simple
[mixer]
src=HOLD0
dest=Ch6
curvetype=expo
points=0,0
[trim1]
src=LEFT_V
pos=TRIMLV+
neg=TRIMLV-
[trim2]
src=RIGHT_V
pos=TRIMRV+
neg=TRIMRV-
[trim3]
src=LEFT_H
pos=TRIMLH+
neg=TRIMLH-
[trim4]
src=RIGHT_H
pos=TRIMRH+
neg=TRIMRH-
[timer1]
type=countdown
src=Ch3
time=180
[timer2]
type=stopwatch
src=Ch3
[safety]
Auto=min
[gui-128x64]
V-trim=59,10,1
H-trim=5,59,3
V-trim=65,10,2
H-trim=74,59,4
Small-box=2,22,Ch3
Model=75,20
Battery=102,1
TxPower=102,7
- Cereal_Killer
19 Mar 2015 16:01 #29887
by Cereal_Killer
Replied by Cereal_Killer on topic v272 ini devo 7e
Wow man that's quite the file!
Does battery level telemetry work? I'd like to start using v272 boards as FC's for larger [brushed] quads (since the work with bradWii) but I'll stick with protoX frames if batt level telemetry doesn't work.
- pmc
19 Mar 2015 16:20 #29890
by pmc
Replied by pmc on topic v272 ini devo 7e
hi
the v272 doesnt support battery tel so i switched it off .
If you use the board for bigger quads dont forget to use bigger FETs to drive the motors.
Time to create page: 0.499 seconds
- v272 ini devo 7e
