How to safely disconnect TX from windows PC?
- 30secs
07 Apr 2015 21:38 #30893
by 30secs
How to safely disconnect TX from windows PC? was created by 30secs
I was wondering what's the easiest, safe way to plug/unplug my Devo 7E from the computer.
Before, when it was connected (usb mode, editing files manually), i would turn the TX off and turn on to use/test. At times it would corrupt the main INI's. Now cause i'm so worried i click on "eject drive" on the computer, then turn it off.
I was wondering, is there a safe way to disconnect drive/turn tx on without having to eject from the pc first?
07 Apr 2015 21:40 #30894
Replied by PhracturedBlue on topic How to safely disconnect TX from windows PC?
generally you should press the eject icon to be sure.
I've never had the issue you described, but the problem is entirely on the windows side. It is not writing to the drive immediately which means the file-system isn't yet written. there really isn't anything we can do from the Tx side (that I know of).
- linux-user
08 Apr 2015 05:58 - 08 Apr 2015 05:58 #30898
by linux-user
Trust me:
Always click "eject drive" on the computer before disconnecting it!
Replied by linux-user on topic How to safely disconnect TX from windows PC?
First click on "eject drive" on the computer, then turn it off !30secs wrote: I was wondering what's the easiest, safe way to plug/unplug my Devo 7E from the computer.
I am not surprised, as this happens with any other USB-storage device as well.30secs wrote: Before, when it was connected (usb mode, editing files manually), i would turn the TX off and turn on to use/test. At times it would corrupt the main INI's.
Trust me:
Last edit: 08 Apr 2015 05:58 by linux-user.
Time to create page: 0.783 seconds
- How to safely disconnect TX from windows PC?
