NEED HELP FOR REPLACING DEVO 7E STOCK MODULE
10 May 2015 06:59 - 10 May 2015 07:01 #32330 by lahiru4216
I have damaged my devo 7e stock module.I have attached some pics of it.I have no idea what to do ?
1. Can i replace Devo 7e stock module with a1705 module ?
2. IF it doesn't what to do ?
{THANKS FOR ANY REPLY]
<<<<<<<<Fly Harder For More Fun>>>>>>>
Last edit: 10 May 2015 07:01 by lahiru4216.
10 May 2015 08:03 #32331 by mwm
No, you can't replace the stock module with the A7105. They are completely different things.
If you check the wiki ModuleList , you'll find links to three different CYRF6936 modules. Any of those should work. The first one is used in the Devo 6/8/10/12s, and while it won't plug into the 7e board, I believe it has been wired in successfully. Neither of the other two will plug in directly either, but they might be less expensive or smaller.
In the future, please only post once, and give people a day or two to answer.
10 May 2015 13:53 #32346 by aMax
Where is the second post..? ...... refering to that....
In case the protective coating of the traces is not physically damaged, your module can be rescued by a person with soldering skills.
There are some shorts now. Removing the solder blob plus some of these solder splashes and restarting the work with a short wire will certainly help.
11 May 2015 06:34 #32378 by lahiru4216
Replied by lahiru4216 on topic NEED HELP FOR REPLACING DEVO 7E STOCK MODULE
Thanks mwm .sorry for the second post.i delete it succesfully.
11 May 2015 06:36 #32379 by lahiru4216
thanks amax ,i will try to give it for repair center.
any link for another module to replace cyrf 6936 module ?
11 May 2015 08:59 #32381 by SadSack
Replied by SadSack on topic NEED HELP FOR REPLACING DEVO 7E STOCK MODULE
www.banggood.com/Walkera-WK-DEVO-S-MOD-U...8S-12S-p-922596.html
That's as good as it gets, hope that helps.
11 May 2015 09:29 #32384 by aMax
lahiru4216 wrote: thanks amax ,i will try to give it for repair center.
... www.hacksmods.com/category/devo-2/
Devo7e with fullsize RF module.
12 May 2015 12:48 #32441 by lahiru4216
Thanks sadsack,the module restock on 13th May , I will looking for it.
16 May 2015 15:05 #32646 by lahiru4216
:) problem solved i ordered walkera devo s -mod module,I will try it ...
30 Jan 2016 17:28 #42425 by Dante1
lahiru4216 wrote: :) problem solved i ordered walkera devo s -mod module,I will try it ...
Did you every get the module replaced? I am in the process of doing the same. Do you have any info on replacing the module?
30 Jan 2016 17:47 #42426 by RedSleds
Replied by RedSleds on topic NEED HELP FOR REPLACING DEVO 7E STOCK MODULE
He doesn't appear to be very active on the site.
A PM might be a better way to find out from him.
30 Jan 2016 17:55 #42427 by Dante1
RedSleds wrote: He doesn't appear to be very active on the site.
08 Mar 2016 15:14 #44264 by lahiru4216
Sorry Everyone for late reply.i got some problems with "account log in".i replaced stock devo 7e module with devo 8s 12s module>>>
08 Mar 2016 15:17 #44265 by lahiru4216
www.hacksmods.com/2014/10/wk-devo-s-mod-module-for-devo7e/
HERE IS THE LINK FOR REPLACING 7E MODULE..
10 Sep 2016 11:39 #53743 by Mr Magik
Replied by Mr Magik on topic NEED HELP FOR REPLACING DEVO 7E STOCK MODULE
Hi there, I have a devo 7e transmitter and I just bought a 8s module and the people who sold it to me are telling me that you can not replace the devo 7e module with an 8s. How did you find out how to do is there any links to a video or info on how to do the install?
Also just want to confirm that this 8 module does definitely work in the devo 7e?
12 Sep 2016 03:25 #53804 by jmcclurg
Time to create page: 0.397 seconds
