New Devo 10?
- SilbernerSurfer
15 May 2015 19:09 - 15 May 2015 19:10 #32622
by SilbernerSurfer
New Devo 10? was created by SilbernerSurfer
short question.
Does the Deviation software working with the new Devo 10? I mean the white one?
Is it possible to solder the modules into the new Devo 10?
Thanks in advance!
Best regards
Uwe
short question.
Thanks in advance!
Best regards
Uwe
Last edit: 15 May 2015 19:10 by SilbernerSurfer.
- SilbernerSurfer
15 May 2015 19:29 #32624
by SilbernerSurfer
Replied by SilbernerSurfer on topic New Devo 10?
- RedSleds
15 May 2015 20:18 #32625
by RedSleds
Replied by RedSleds on topic New Devo 10?
The only difference, other than being an ugly white w/ orange trim switches, is that the white one has a higher gain antenna on it. I believe a 5dB instead of a 3dB.
If you are more inclined to get a gun metal black one, Walkera Helicopter Supply on San Juan Island, WA., and banggood.com (for a better price if you can stand the wait) in China still have them available.
- Stavross118
15 May 2015 20:31 #32626
by Stavross118
lol
Replied by Stavross118 on topic New Devo 10?
I like my ugly white one it matches my non tan and a couple of hellis I've got and works great with modsRedSleds wrote: The only difference, other than being an ugly white w/ orange trim switches, is that the white one has a higher gain antenna on it. I believe a 5dB instead of a 3dB.
- SilbernerSurfer
17 May 2015 11:40 - 17 May 2015 11:43 #32685
by SilbernerSurfer
I like the white one very much!
I found this Module with plugged on antenna at BG.
www.banggood.com/DEVO-Transmitter-Tuner-...ys-V922-p-89812.html
At the white Devo 10 the antenna is screwed on the transmitter case. So no possibility to slide the nrf antenna into the stock antenna tube.
Where should i place the nrf antenna? Are there any descriptions for soldering the Modules into the white devo 10?
I will try to avoid a second antenna tube at the transmitter case.
Last edit: 17 May 2015 11:43 by SilbernerSurfer.
- aMax
17 May 2015 17:19 - 17 May 2015 17:23 #32696
by aMax
Replied by aMax on topic New Devo 10?
Just put the antenna sideways under the top of the case. Every RF module needs it's own antenna.
Most users are going this way. This is the best angle for RF emission.
Secure the U.FL plug at the module..!
Last edit: 17 May 2015 17:23 by aMax. Reason: adding a sentence
- SilbernerSurfer
17 May 2015 17:59 #32699
by SilbernerSurfer
- RedSleds
17 May 2015 18:36 - 17 May 2015 18:37 #32701
by RedSleds
What are some ways to do this? ....and still be able to un-hook it when needed?aMax wrote: ........Secure the U.FL plug at the module..!
Last edit: 17 May 2015 18:37 by RedSleds.
- aMax
17 May 2015 20:55 #32708
by aMax
This is my advice in the case the module is not fixed inside the tx.
...just my 2C
If not covered with a shrink tubing, a small amount of hot glue will work.RedSleds wrote:
...just my 2C
Time to create page: 0.316 seconds
- New Devo 10?
